5.4 F150 rough idle - Ford Truck Enthusiasts Forums
5.4 F150 rough idle
Old 05-26-2000, 01:00 PM
bigsnag's Avatar
bigsnag bigsnag is offline
bigsnag is new and has a neutral reputation at this point.
5.4 F150 rough idle
Old 07-29-2000, 11:00 PM
rjj rjj is offline
rjj is starting off with a positive reputation.
5.4 F150 rough idle
I have a 1999 F150 with a 5.4 engine. My question is does anyone else have a rough idle when in drive with foot on brake? This is a very noticable mis at all stop signs and red lights.This problem existed when I picked my truck up new from dealer. I have had it in twise for repairs but Ford cannot smooth out this idle problem. Any suggestions for this problem????
Old 08-14-2000, 10:53 PM
Mikeman Mikeman is offline
Mikeman is starting off with a positive reputation.
5.4 F150 rough idle
Does the problem only occur when your foot is on the brake? If you have cruise control and there is a vacuum dump valve (like on my '91 and '95 Fords), then the vacuum dump valve may be your problem. The vacuum dump valve vents vacuum to the cruise control servo when you press on the brake to cancel the cruise control. If it is stuck open when the brake pedal is pressed, it will be like a vacuum leak and possibly make the truck run lean. It would be easy to check by pulling the vacuum line to the dump valve and plugging it, then see if the problem is there. Just a thought, don't know how likely that this is your problem.
Old 08-27-2000, 11:03 PM
dd976 dd976 is offline
dd976 is starting off with a positive reputation.
5.4 F150 rough idle
I have a '97 F150 with a 4.6 and it does the exact same thing...rough idle (intermittent) when slowing down at lights/stops. It doesn't appear to be a tranny problem, at least with mine. It is somewhat inconsistent, however. For example, if I am slowing down at a light and encounter the vibration, I ease off the brake a little and let it move forward (usually about a foot or two) and the vibration completely disappears. Could this be the same vacuum problem as discussed in the other email? Any info would be appreciated as this is a confusing problem. Thanks.
-Mike
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 12:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 01:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 09:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 10:13 PM
Tags
01, 1991, 97, f150, ford, idle, idling, intermittent, lightning, lights, problems, rough, shaking, stop, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
