1997 f150, dead - Ford Truck Enthusiasts Forums
1997 f150, dead
Old 02-06-2000, 09:35 PM
Trail_Rider Trail_Rider is offline
Trail_Rider is starting off with a positive reputation.
1997 f150, dead
Old 01-06-2001, 03:07 AM
codym codym is offline
codym is starting off with a positive reputation.
1997 f150, dead
The truck won't start with the key. I turn it to start, bam, starter relay fuse blows. I turn it to run and jump it over at the solenoid, starts right up. The solenoid is brand new, starter tests perfect, no bare wires from battery to solenoid to starter. Any one have any ideas??????
Old 01-06-2001, 09:13 PM
fordgt500kr fordgt500kr is offline
fordgt500kr is starting off with a positive reputation.
1997 f150, dead
Try the following:
Verify that the fuse that is blown is the proper rating.
Replace the blown fuse with a good fuse with the proper rating.
Disconnect the small red connector from the terminal on the relay.
Turn the ignition key to the START position.
If the fuse does not blow, the problem is in the relay.
If the fuse blows again, the problem is most likely in the ignition switch.
The ignition switch may be miss-adjusted with respect to the key position, or the ignition switch may be at fault.
To check for miss-adjusted ignition switch;
Make sure that the small red connector on the relay is properly reconnected. Very slowly turn the ignition switch to the start position. Note whether or not the engines tries to start. Stop turning the key as soon as the engine tries to start. If it does try to start, this pretty much proves that the ignition switch is miss-adjusted.
Good Luck
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
dead, f150
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
