Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-11-2007, 02:30 PM
staysbroken staysbroken is offline
1978 Ford F-100
My Garage
staysbroken is starting off with a positive reputation.
Worth it to replace factory muffler?
If I replaced the factory muffler on my 97 Ranger with a cheap parts store turbo muffler, would I see any appreciable gains in power or mpg? I suppose it all depends on how (if at all) restrictive the stock muffler is. Also, how much louder would a turbo muffler be than the stocker? This is the only thing that's really kept me from going ahead and doing it already, since IMO the only good sounding 4 cylinder is one I can't hear.
Thanks guys
__________________
1978 F100 For Play... SOLD! 501 stroker, ported Edelbrock Performer RPM heads, ported Performer RPM Air Gap, Comp Cams XE274H
1997 Ranger For Work... 2.3L/T5
1979 Honda CB750K
  #2 (permalink)
Old 08-11-2007, 07:02 PM
TLyttle TLyttle is offline
Garage is empty, add now
TLyttle is starting off with a positive reputation.
I found the aftermarket turbos to be very effective on some vehicles, not so much on others. I have a habit of buying an oversize muffler and sleeving it down to match the pipes: the larger muffler seems to cut back on backpressure and run quieter. Mind you, I always drill a 1/4" hole at the back to allow moisture to drain out...
  #3 (permalink)
Old 09-15-2007, 02:36 AM
1978 Ford F-100
My Garage
If anyone else was interested, I went ahead and put a Cherry Bomb turbo on it, and it did give a noticeable increase in performance. It's not too much louder than stock either.
__________________
1979 Honda CB750K
  #4 (permalink)
Old 09-15-2007, 12:43 PM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
I got an el-cheapo from Advance that fits my 2.3. It also fits the 302. I figure if it can handle 302 cubes of exhaust, my 140 will go thru easily. It does, and I think it has more power. Factory quiet, too. Best $20 I ever spent. Don't like the rusticles in the eye, though.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #5 (permalink)
Old 09-24-2007, 08:30 PM
DesertStorm's Avatar
DesertStorm DesertStorm is offline
DesertStorm is gaining momentum as a positive member of FTE.DesertStorm is gaining momentum as a positive member of FTE.
I replaced my exhaust from the manifold back with 2.5" aluminized steel with high flow cat/2.5" cherry bomb muffler with a 3" tip turned in front of the rear wheel. Got about 1-2 mpg more and lots of mid range/top end power. Lost a little bottom end but thats ok with me. Although the sound police and neighbors dont like me.
Tags
1997, factory, ford, it, muffer, muffler, ranger, replace, replacing, restrictive, stock, tailpipe, trucks, turbo, worth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
