Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Competition Diesel racing, sleds, dynos, power tuning and max performance.
  #1 (permalink)
Old 08-11-2007, 06:30 AM
dartdiesel dartdiesel is offline
Garage is empty, add now
dartdiesel is starting off with a positive reputation.
horse power
howdy boys, I'm new here so I may need a little help. But I'm all ears ,any way I have two '85' F250 ext cabs with the 6.9L in them . I'm going to rebiuld one to drag race . One of them has a banks turbo on it and is an automatic. Is this a good combination and how much horse power can I sqweeze out of that 6.9L.
  #2 (permalink)
Old 08-31-2007, 11:39 PM
turboman24 turboman24 is offline
turboman24 is starting off with a positive reputation.
Well 6.9s are not really good engines to make a lot of power with. The biggest factor being the ability to hold the head to the block even with studs. The second being able to flow tons of fuel. It can make some pretty good power at the expense of a big hole in your wallet. If you are going to you would need to drop the compression ratio by shaving the pistons and getting head studs. Then you could run in the 20lbs of boost with the wastegate shut. To get past 30lbs your are going to need to have your pumped worked over and some custom injectors. The big problem though is when you drop the compression to be able to run that much boost then it gets hard to start in cold weather. Wish you well though with your project
__________________
"I lie down and sleep; I wake again, because the Lord sustains me."84' Ford F-250 4x4 single cab IDI - No Turbo MODS: Soup Bowl/ ram air, 3" exhaust most of the way, aftermarket tach worth 25+ HP !
  #3 (permalink)
Old 10-07-2007, 06:14 PM
George D.'s Avatar
George D. George D. is offline
1994 Ford F-350
George D. is starting off with a positive reputation.
You can also get heads with fire rings in the heads to help keep the boost in you might also want to try the IDI fourm there pretty knowledgeable over there.
  #4 (permalink)
Old 10-08-2007, 04:47 PM
lukecline lukecline is offline
lukecline is starting off with a positive reputation.
you might as well drop a cummins in it.
__________________
99 cc f250 4x4-wildman tuning, wop twins, di ic, richter trans, casserly fuel
96 cc f250 4x4 -38r turbo, stage 1's, TW tuning, elec fuel system, stage 1 trans, intercooler- formerly 12.52 @ 110 mph
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
