Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 08-10-2007, 06:09 PM
COLEnMICHAELS66 is starting off with a positive reputation.
best distributor?
what is the best disributor for the 400's? i am building 400 from a 79 F250 its mildly built, nothing crazy. i have a ProComp HEI unit that i got off of Fleabay. but the more i look at it the more i dont lke it. its huge and bulky and just kinda ugly. i was looking at the MSD Billet series. are they any good? maybe Mallory?
  #2 (permalink)
Old 08-10-2007, 07:03 PM
danlee's Avatar
danlee has a good reputation on FTE.danlee has a good reputation on FTE.
The Davis Unified Ignition (DUI) is good, but it is a bulky HEI like the Procomp, but costs more.
http://www.performancedistributors.com/forddui.htm
MSD makes excellent distributors. I like MSD better than Mallory, but I ran a Mallory Unilite for several years with no problem. I needed the smaller Mallory Unilite to clear the raised 351C-4V intake manifold because I had 4V heads on my 400. Currently I have a Procomp TFI distributor, since my motor is EFI.
There is nothing wrong with a Duraspark distributor either.
__________________
JOIN THE DELAWARE CHAPTER, CLICK HERE
  #3 (permalink)
Old 08-13-2007, 12:42 AM
Matts72's Avatar
Moderator- High Plains
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
DUI, ProComp, MSD, Mallory, and the factory unit are all excellent distributors. I've used MSD and Mallory units personally and they are great units, the factory Duraspark is a good unit too, I almost always switch it out for a MSD or Mallory, but I've never had one fail me.
  #4 (permalink)
Old 08-13-2007, 12:54 AM
roger dowty is gaining momentum as a positive member of FTE.roger dowty is gaining momentum as a positive member of FTE.
Eric promotes the factory set up (duraspark) as it has everything a typical motor needs performance wise and has the advantage of retarding timing during start and having the parts in every parts store etc.
I've owned several duraspark systems and nearly all of them have given me headaches...but i'm not really up on trouble shooting. It's one of the most frequent problems on the site...problem could be anywhere in a rather complex system compared to others.
So far i really like the HEI system that is no available...yea, it's a bulky top and you will likely need to raise your stock air cleaner or carb...but thats not a bad deal anyway...then you have ONE wire from the ignition..Two if you hook up a tach. It's also a very popular system so parts are everywhere as well as internals and they are cheap enough you can buy 3-4 complete units for what a complete msd would cost. And you could go with the curved distributor as stated above for a bit more.
If money were not an object i'd probably have the msd with adjustable timing in the cab.
__________________
'77F1504x4, '75 f250crew4x4, '79 Bronco 429, '83 bronco, '72 Torino with 351cj, 70 1/2 falcon, 75 stangII. all projects, 2 on the road. One pissed off wife!
  #5 (permalink)
Old 08-16-2007, 03:04 PM
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
Quote:
If size is a problem, we also offer a very nice Duraspark distributor:
http://www.performancedistributors.c...dduraspark.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
  #6 (permalink)
Old 08-16-2007, 03:55 PM
Matts72's Avatar
Thats the first I've seen the Duraspark from you guys, but if the Pertronix on my 72/360 ever gives out, I know what I'm going to replace it with. That is a very nice unit.
  #7 (permalink)
Old 08-16-2007, 06:37 PM
unrulee's Avatar
unrulee is starting off with a positive reputation.
I like my DUI HEI on my 400. Eliminated a ton of wiring, and the electronic box.
__________________
Lee
STGs Minions - Frozen F-Series
1979 F250 Ranger 4x4, where to start? lots of stuff added!!!
2005 F250 Lariat FX4, SCREW, 6.0 PSD, making progress
"Instruction manuals are nothing more than another man's opinion."
  #8 (permalink)
Old 05-04-2008, 05:22 PM
ninoford is starting off with a positive reputation.
Unrulee,
I just bought a hei for my 400m, came with no info, what is the firing order for the cap on the hei? and how do I wire it up?
Thanks
  #9 (permalink)
Old 05-04-2008, 08:18 PM
JBradley500 is starting off with a positive reputation.
there should be 2 prongs on the cap you plug up to. ones for the power wire and ones for a tach. its really not hard.
__________________
  #10 (permalink)
Old 05-04-2008, 09:52 PM
unrulee's Avatar
This may help as well Ford 351C 351M V8 Engine Specs-Torque Specs-Cylinder Numbering-Firing Order-Distributor Rotation.
__________________
Lee
  #11 (permalink)
Old 05-10-2008, 02:41 PM
EFM EFM is offline
EFM is starting off with a positive reputation.
has anyone used the mallory 85 series HEI. summit sells it for 180. I'm still
debating what to install on my 351c once I get to that stage on my build.
  #12 (permalink)
Old 05-10-2008, 08:16 PM
80broncoman is starting off with a positive reputation.
What is so wrong with factory eletronic ignition? I'd never had a problem with the duraspark or duraspark II systems being reliable.
If you need more ignition power just use something like the new Crane cams ignitions boxes. They have much more moderen eletronics than most of the MSD stuff.
__________________
Real men don't wear Bowties
  #13 (permalink)
Old 05-18-2008, 10:39 PM
farmer ford's Avatar
farmer ford is starting off with a positive reputation.
Quote:
so did you eliminate the brain box on the fender well? what other wires did you eliminate?
__________________
1978.5 F250 stndrd
l. b. 4 speed manual
3" lift 315/75/R16 SXT's
lund moonvisor, custom
paint(dodge blue, viper
silver) home made winch
bumper Warn 9000
diamond plate tool box
1995 F350 4 dr l. b.
PS 5 speed manual
superchips 315/75/R16
SXT's 3" lift, tool box
100gal. transfer tank
  #14 (permalink)
Old 05-18-2008, 10:44 PM
unrulee's Avatar
Yeah the box on the driver side fenderwell, and the wiring that ran to the stock dizzy.
__________________
Lee
  #15 (permalink)
Old 05-19-2008, 03:22 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
I have one in my 63 F100 351W. All you need is one hot wire from the key and if you have a tach, a wire for that. It's a nice set-up.
It fires much better than my Duraspark from a 84 F250 did, because with it ibstalled it burns cleaner and I have to turn the idle screw down with them both set @ 12* BTDC
DUI Ignition Installation In A Ford 351W V8 .: Articles
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
