Molded Radiator Hoses? (Y-Block)
Hey everyone ... I'm gearing up for a motor swap, real soon ... a 292 Y into my '60 F-100. The guys at the Y-Block forum here have been real helpful with obtaining parts, etc., and I was hoping the '57-'60 guys here, and maybe the '54-'56 guys could help me.
I'm hoping to hook up the Y (to a stock rad.) with no flex radiator hoses. The AutoZone where I work lists a molded hose for the upper, but not the lower hose. I was thinking of just going in and trying to match one up, but then it occurred to me that maybe someone here had already done it.
So the question is, do any of you fine folks happen to have a part number (from any major store/manufacturer) for a molded lower rad. hose for a '57-'60 truck with a Y block? Thanks in advance.
B9TT-8260-B .. Upper Hose (Motorcraft KM-231)
C2TZ-8286-D .. Lower Hose (Motorcraft KM-238)
I found a molded lower hose for my y-block to mopar radiator by building a jig and finding the perfect fit in a matter of minutes. Part no. 70445 at Advanced Auto.
This is not much help owing to the fact that I deleted the pics I had of the neat jig that I had made and recorded. Also not helpful is the fact that it is in my '54 and has a Mopar radiator. There was a flash of foresight when I recorded the part number on the wall of my shop, but that may only be helpful to me. Looks like you'd be better off with Numbers numbers.
hopelessly, himmelberg
How about the original 1957/60 Ford Part Numbers?
Wow, that sounds better than I expected. The only question is, can I order these parts through a Ford dealer, or what?
EDIT: FTE sponsor Green Sales has 10 of the lower hoses. Gen-U-Ine Ford originals. See their link above ^^^ type in c2tz8286d. No hyphens, just like that.
EDIT part II: They also have the upper hoses, 6 of them = b9tt8260b
Green Sales: 800-543-4959 in Cincinnati, Ohio. Green is the world's largest dealer in obsolete Ford parts.
I have a flex hose on the upper one, but my bottom hose is a molded hose and just bolted on. I am running a stock Y-block and the stock radiator.
Did you find something or so you still need the part number?
I would love to have a correct upper hose too, if anyone ever finds one that will fit. LOL
51A-8333-A .. Molded Flexible Hose ~ 36" long x 1 1/2" I.D. = REPRODUCED - also used on Flathead V8 cars & trucks. Not only is the hose reproduced, but has the correct Ford script on the hose.
