tachometer on 5.4L engine
Old 11-27-2001, 07:03 PM
terragate's Avatar
terragate
terragate is offline
Post tachometer on 5.4L engine
I want to install a tachometer on my 2001 E350 Van. There is no option to buy a factory tach. Where would I attach the aftermarket tach to receive the RPM signal. The van has a coil at each spark plug and has a "distributorless" ignition. Help!!
Old 01-03-2002, 08:35 PM
MAK301's Avatar
MAK301
MAK301 is offline
Look at the wire harness somewhere by the brake booster there may be a wire there with a tag on it "CTO" and it is white with a pink stripe
Tie into that and you should be good.I just did all this on my 98
Ford E-350 Van, hopefully everything is the same on yours.
Old 01-03-2002, 10:01 PM
wmcnally's Avatar
wmcnally
wmcnally is offline
MAK301,
Great info! I have a '98 4.6 E-150. I'd like to add a tach. Will you post some more info? What type/brand tach did you add? Where did you mount it? Any tips on installing it? Thanks in advance for your help.
Old 01-04-2002, 04:41 PM
nitrobologna's Avatar
nitrobologna
nitrobologna is offline
KB 80 F-150
15
09-04-2018 04:23 PM
Ford_Six
11-26-2016 04:36 PM
big ole ford
07-19-2016 07:01 PM
AKHunter93
06-06-2016 10:31 PM
Njmyers
11-12-2015 08:00 AM
Quick Reply: tachometer on 5.4L engine
