Regretable Upgrades
I tried Beltech lowering shackles that didn't work out. I tried all different pinion angle shims and couldn't get rid of the vibration. I have an SCab which has a 2 piece driveshaft and from what I hear a small percent of them have this problem. I put it back to stock and now have no vibe.
Dual exhaust from a local shop near me. I lost a lot of low end on my already slow truck and it sounded like crap. Just keep it stock or buy one of the major brands only after you have heard and rode in a truck with the same exhaust. To me a loud exhaust is embarrassing when pulling up to a clients place of business.
for me the edge progammer was a waste. Not so much the performance but the pod is terrible. I like the gauges but it looks like crap and drives me crazy. It has also messed up my interior the pod scratched the plastic. For the performance vs. headaches I would give the edge a thumbs down.
The EDGE Evolution in my '07 F150 5.4L stays in afterall, wife decided that it Is best to keep using it.
I have found that the EDGE does do what EDGE claims, more HP/improved overall power thru-out the RPM's.
I have had no-problems with the mount on the dash & mine is just sitting up there as I didn't use the velcor, even on rough dirt roads the EDGE POD has not moved a bit.
I did have to return the Volant CAI for my '07 but only b/c I couldn't get it to fit where it was suppose to in the '07 inner fender area.
I added a Flowmaster series 50 single cat-back exhaust too, no regrets.
The only mod I wish I could undo is the aftermarket reverse sensor system I permanentely installed in my bumper. Only if I had known that the damn thing speaks instead of just beeping - there's no way to turn it off. Sounds like a little girl yelling out in meters instead of feet. The image kinda clashes with the whole "driving a truck" thing.
