Brake and Power Steering noise.
What powers your truck? I ask because gassers and diesel have different braking systems.
Did you check the power steering fluid? If a diesel, the pump operates the brake booster.
If the fluid is okay you can try and do a fluid swap to synthetic to see if that helps. If not, you may need a new pump...or a set of earplugs.
It's a diesel so I'm thinking it's probably the booster then. I don't really know what else it could be.
When you're doing both at the same time you're putting the strain on the p/s pump not the booster. If your brakes are working fine and have a good pedal I wouldn't screw with the booster. I'd go with Monsta's recommendation and do a fluid change. Use a synthetic.
Also can you describe the sound better?? If it's like a growling, whirring sound it's the pump. Good luck.
I was checking around the power steering pump ans I found a hard line that was loose on the bottom. Would that line being loose cause that sound? I was thinking that the pump was getting air bound. I also found some fresh fluid on the underneath of the line. So I cleaned it up and will see if it still leaks. Any other suggestions would be helpful. Thanks.
Well with it running take off the cap and turn the steering wheel from right full lock to left full lock a few times. Do it slowly. This will bleed the system.
Well I haven't done that yet but it is still leaking and making that noise. I think my power steering pump is starting to go out now.
morganftrucks
03-09-2015 07:08 PM
