Head removal on a 5.4L
Old 08-09-2007, 07:19 PM
reel_story's Avatar
reel_story
reel_story is offline
<TABLE><TBODY><TR><TD vAlign=top width="100%">Can the pasenger side head be replaced without removing engine? Can a piston be replaced on a 5.4L without removing the engine? I am contemplating purchasing a truck with a valve or piston issue and trying to get a feel for the repair time. Is it easier to remove the cab to remove heads and/or the engine like I have heard? (vs pulling the engine out the front)
Thanks,
reel_story
</TD></TR></TBODY></TABLE>
Old 08-09-2007, 07:33 PM
reel_story's Avatar
reel_story
The engine is in a F250 super duty
Old 08-09-2007, 08:02 PM
Soilman's Avatar
Soilman
Soilman is offline
This is the right spot! This forum doesn't get the traffic the SD forum does but this is the spot for the answers. Just hang in there and some of these engine guys will be along shortlly.
Right Guys!!
Old 08-10-2007, 12:17 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
There should be enough room in a SD. The oilpan is the only concern as fas as getting the piston out. The heads can be removed in a F150, but it's really tight.
Old 08-13-2007, 08:44 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
BURNSTOUGHFORD is offline
Pulling the engine isnt bad at all if you have a engine picker... just pull the intake manifold and disconect everything on the engine... you will need to pull it to put a new piston in. This can only be done from the bottom
Old 09-28-2007, 12:02 AM
84ttb's Avatar
84ttb
84ttb is offline
Well it IS POSSIBLE to replace a piston with the engine in the bay..... you'll have to unbolt the tranny and engine mounts and actually jack or lift the engine up as far as possible to deal with oil pan clearance....It really isn't TOO much more trouble to just pull the engine, and after that, everything is MUCH easier..... Removing the heads is something I would go ahead and leave the engine in place for unless you were just feelin' frisky
51dueller
104
03-08-2024 04:09 PM
vloney
6.7L Power Stroke Diesel
11-02-2013 09:56 PM
Buckbuster
6.4L Power Stroke Diesel
16
01-16-2011 10:35 AM
amgpro2
10-04-2010 12:58 PM
96_4wdr
Aerostar
03-05-2008 02:09 AM
Quick Reply: Head removal on a 5.4L
