Head removal on a 5.4L - Ford Truck Enthusiasts Forums
Old 08-09-2007, 07:19 PM
reel_story reel_story is offline
reel_story is starting off with a positive reputation.
<TABLE><TBODY><TR><TD vAlign=top width="100%">Can the pasenger side head be replaced without removing engine? Can a piston be replaced on a 5.4L without removing the engine? I am contemplating purchasing a truck with a valve or piston issue and trying to get a feel for the repair time. Is it easier to remove the cab to remove heads and/or the engine like I have heard? (vs pulling the engine out the front)
Thanks,
reel_story
</TD></TR></TBODY></TABLE>
Old 08-09-2007, 07:33 PM
The engine is in a F250 super duty
Old 08-09-2007, 08:02 PM
Soilman Soilman is offline
Soilman is starting off with a positive reputation.
This is the right spot! This forum doesn't get the traffic the SD forum does but this is the spot for the answers. Just hang in there and some of these engine guys will be along shortlly.
Right Guys!!
Old 08-10-2007, 12:17 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
There should be enough room in a SD. The oilpan is the only concern as fas as getting the piston out. The heads can be removed in a F150, but it's really tight.
Old 08-13-2007, 08:44 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
Pulling the engine isnt bad at all if you have a engine picker... just pull the intake manifold and disconect everything on the engine... you will need to pull it to put a new piston in. This can only be done from the bottom
Old 09-28-2007, 12:02 AM
84ttb 84ttb is offline
84ttb is starting off with a positive reputation.
Well it IS POSSIBLE to replace a piston with the engine in the bay..... you'll have to unbolt the tranny and engine mounts and actually jack or lift the engine up as far as possible to deal with oil pan clearance....It really isn't TOO much more trouble to just pull the engine, and after that, everything is MUCH easier..... Removing the heads is something I would go ahead and leave the engine in place for unless you were just feelin' frisky
The Canadian Vin Info Thread 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 63 12-04-2016 05:04 PM
just so you'll know vloney 6.7L Power Stroke Diesel 6 11-02-2013 09:56 PM
After Market Air filters Buckbuster 6.4L Power Stroke Diesel 16 01-16-2011 10:35 AM
Turbo Rebuild kit. amgpro2 6.0L Power Stroke Diesel 6 10-04-2010 12:58 PM
Ford TSB procedure for de carboning 4.0L 96_4wdr Aerostar 1 03-05-2008 02:09 AM
Tags
54, 544, crankshaft, cylinder, duty, e350, engine, f150, ford, hard, head, intake, removal, remove, super, titan
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
