You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Mine doesn't actually hold a vacume. I have vacume going to the can, but none comming out.
I forgot what it does.
Should i fix it?
__________________
Talyn (AKA: der Schafen Führer)
1994 F250 XLT 4x4 Standard Cab - T-444E Direct Injection Turbo Diesel, 5 SPD M/T Z/F S5-420, Rosewood 160cc Stage 1's, PHP Tuner, 6637, Short Throw Shift Kit, Valair Kevlar/Ceramic, 140V IDM, T-500, 285/75/16 Cooper Discoverer ATR. Steyr C9-A1. You can get more with a kind word and a 2x4 than you can with just a kind word.
Your vacuum can stores "a vacuum" so that your climate controls still work under acceleration. you can pressurize it with no more than 15 psi to check for leaks. I fit leaks replace it.
Yea, my Vents change during accelleration sometimes.
Better change it then.
Thanks crash!
__________________
I checked the vacuum a while back. And got nothing out of the can.
But the in line for the vacuum read good.
I thought I was having a vacuum problem causing my poor gas mileage.
It's a bad FPR.
__________________
