Factory PCM flashes....
I have got the latest flash that runs the idle up and down at idle............
Since then I have lost 10 mph pulling the toy hauler up the hill to Flagstaff AZ?
Should I ask the dealer to flash my PCM back to a different flash?
Is there a factory flash that was best for power and mpg??
THe truck runs great when not towing mpg' are down 1-2 mpg...fuel filters and air filte is new?????
Originally Posted by BowTieHatr
what flash was it? there are two flashes, and one can be a problem.
I received the "inductive heating" flash and all updates in the Spring and lost 2 mpg. Truck runs fines and seems to be bullet proof, but my mileage dropped as soon as it was flashed. I thought that maybe the ULSD fuel maybe caused it.. or some of it anyways.
I was always told by you and VLoney that a flash either takes or it does not. Upon watching my tech do it... no codes and he let it idle to relearn the "at idle/EGR closed" strategy.
Is there a new flash or what is the "problem flash"???
Thanks,
03s and early 04s have the flash that can cause issues because it makes the truck more sensitive in general. late 04s and up has the other flash. all trucks have the inductive heating strategy, but its the rest of the program that can cause issues.
How do I know if I have a good or defective PCM/TCM strategy???
What do I ask for or say to my 6.0L dealer tech. Since I am past 100,000 miles, it would have to be "on the side".
Is there a service bulletin to advise techs about this issue???
Originally Posted by EZ-Ford
I have asked that before also, how do we know what flash is installed?
With the information that comes up in the ODO display in test mode, there are some values for ROM version and such. Will one of these identify what the flash level is (maybe through a secret decoder ring...).
Here it is right off the OASIS report.... 2004 Ford Excursion 6.0 4x4
REPROGRAMED PCM TCM AND FICM TO 4U7A 12A650 ENG. NEC TO RPLC EGR VALVE PLUGED CODE P0401 P0404
Anyone knows what the he#! that all means?
I got the EGR valve plugged part!
What's the REPROGRAMED PCM TCM AND FICM TO 4U7A 12A650?????
I've been using the 06E17 program, which disable the EBP sensor, on my build date 1-2-03 for about 6-months, and for the most part I'm satisfied.
This was not by my choice, but since I live in Kalifornea, it was mandated by the DMV, otherwise they would not re-regester my truck.
The EBP is now "inferred" based on: MAF, MAP, BARO and EOT. So if any of these sensors fail or have intermitten issues there's bound to be problems.
The program also cylces the EVRT during idle to reduce the sticking vane issue.
I would pay to have my original program back. The truck has never been the same since these mandatory flashes.
IWith the information that comes up in the ODO display in test mode, there are some values for ROM version and such. Will one of these identify what the flash level is (maybe through a secret decoder ring...).
Originally Posted by Casey
Pay who? The tools that the dealer has can only put the latest flash on the PCM/TCM. It can't go back.
This is a commom feature on most of the tuners out there were you can revert back to the exsisting program.
Perhaps Matt has this program?
Krazymaan
08-24-2011 06:53 AM
