trans ratio and final drive ratios
ok im trying to figure out what the trans od ratio is and transfer ratio is on a 03 ford f150 4x4 with 4.6l automatic and what would the most likely alxe ratio is im going to be changing to larger tires and would like to change the alxe ratio to get the same rpms at 55 mph that would with stock tires
Take a look at the door sticker on your truck. Get the numbers or codes where the sticker says AXLE and TR. Either list them here or use this link to find out yourself.
https://www.ford-trucks.com/article/...r_Decoder.html
Other FTE users will chime in to tell you what gear ratios to use with your chosen tire size. BTW, you will have to get gear sets for both axles, which will double the cost of a gear change. Good luck!
Originally Posted by douboy80
ok well i have a 3.55 axle and a 4r70w trans so does anyone know what the ratio out of trans and transfer case is in OD
Rusty_S
09-30-2016 10:17 PM
Daleksandrovich
03-22-2014 09:37 AM
bushmstr02
11-29-2009 11:24 PM
Shanemh
06-13-2007 03:00 AM
ANIMAL
11-18-2003 06:16 PM
