351 vs 5.4.....
351 vs 5.4.....
The current 5.4L in the f150 is good for 260hp, how can you get 400hp without going internal? Pulleys, chip, mass air flow with a K&N, header, exhaust, throttle body, plugs, wires are availiable, but don't add 140hp. This isn't an arguement, just an exchange of opinions, and hopefully some insight if there is other options to gain hp. What else can be done without a blower strapped on? Any info would be greatly appreciated. I have a 4.6L, and would like to know if it can work on my triton.
on
351 vs 5.4.....
[updated:LAST EDITED ON 07-Mar-02 AT 10:53 PM (EST)]I agree Benjamin, but the problem with the triton there isn't any internal mods availiable, that I could find. You can modify the Mustang tritons, but nothing is compatible with the truck tritons according to the sources I've talked to. If there was cams, cylinder heads, intake manifolds availiable I wouldn't think about swapping, but there isn't. If you know something I don't about internal mods, such as a source for these mods, please let me know. It would be greatly appreciated.
351 vs 5.4.....
400 HP on a naturaly asperated 5.4??? Do tell, im working hard to find anyhting t=other than a charger (blower) to get any kind of result out of mine. Ive done everything from K&N, Chip, Throttle body spacer, Exhaust... What else is there that i could see really any differnce. Ive gone up against 351 windsors all over, and im still getting my butt kicked hauling up the highway in the hills. I would really apreciate feed back on what people have tried without going internal. Im concidering looking into buying a 5.4 block and just custom building it to get what im looking for with naturaly asperated. My problem is, if i were ot charge my truck, I woudl in time eventually end up tearing the engine out of my truck to rebuild, so why not do it now?
Thanks
S
Thanks
S
on
351 vs 5.4.....
I'm sure if someone had the knowledge, resources and cash you could get 400 hp out of a 5.4, or 350hp out of a 4.6, but it's all custom work. There's nothing you can look up in a catalog and price out, order, and slap in. A 5.8L, you could crate order a 385hp motor compared to custom building a 5.4 at a huge expense. I wish my '97 had a 351, or 302 compared to either new tritons, because i could build either engine up in the 300hp plus range, and still run pump gas. Can't do it on a triton without spending huge cash.
351 vs 5.4.....
I was thinking about the 5.4 in the cobra r. I think SVT bought the parts for the engine instead of making them. I don't know where from. I agree with you about it being much easier to find parts for a 351. Alot of the parts for the 4.6 will work on the 5.4. I am almost positive I saw performance parts for the 5.4 in a book somwhere but I can't find them. I may be wrong. Benjamin
351 vs 5.4.....
actually these triton engines already have a very good bottom end. i think that the way to get hp out of these triton engines or any engine fer that matter is in the heads. a good cam, the right compression, and the properly ported heads will make or break an engine!
-nathan
-nathan
