What is an "RV" cam - Ford Truck Enthusiasts Forums
What is an "RV" cam
Old 08-08-2007, 05:46 PM
fastmover's Avatar
fastmover fastmover is offline
fastmover is a splendid one to beholdfastmover is a splendid one to beholdfastmover is a splendid one to beholdfastmover is a splendid one to beholdfastmover is a splendid one to beholdfastmover is a splendid one to beholdfastmover is a splendid one to behold
What is an "RV" cam
What is the difference between a stock, RV, and Roller cam? The guy who just rebuilt my engine said he put an RV cam into my 390.
Thanks,
Karl
Old 08-08-2007, 06:59 PM
Redmanbob's Avatar
Redmanbob Redmanbob is offline
Redmanbob is gaining momentum as a positive member of FTE.Redmanbob is gaining momentum as a positive member of FTE.
Cheap lol I dunno, put one in my 352 and it seems to have a lot better grunt than before. I like it. Not much on the high end I dont think but it's a truck, i tend to drive it like one.
Old 08-08-2007, 07:20 PM
bluesky636's Avatar
bluesky636 bluesky636 is offline
bluesky636 is starting off with a positive reputation.
RV cams are designed more for low-end torque than high-end horsepower. The cam in my Galaxie is an RV cam. Since it is a cruiser, having the low end torque is great.
Old 08-08-2007, 10:03 PM
Putt's Avatar
Putt Putt is offline
Putt is gaining momentum as a positive member of FTE.
A stock cam is a compromise between power, mpg, smoothness, idle quality, etc. An RV cam is optimized for low rpm torque at the expense of some hp at higher rpms and will often net more mpg. A roller cam is the type of lifter used, it does not mean any particular type of power band. Normally a roller cam has more lift with less duration due to the more aggressive ramps used compared to a flat tappet(hydraulic or solid lifter) camshaft.
Old 08-09-2007, 06:23 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
RV cams are those having specs in these ranges: 250-270 degrees advertised duration and lifts ranging from the .470's to .515 (give or take an extra .010) The @.050 duration is typically about 200-215 degrees duration. The Stock 428 CJ cam falls into this category. They're basically improved stock type cams but less than what would be called a hot street cam.
Old 08-10-2007, 12:24 AM
Redmanbob's Avatar
Seems like the cam I installed was .483/.517 and @ 50 204 ? Barry sold a cam on survival that was a match but looks like the #'s have changed. I'd say for daily and mudding your in business, unless the mudding is competition then >???? But I'm pretty sure this cam could jerk the **** outa an elephant!!
Old 08-10-2007, 01:31 AM
sierraben's Avatar
sierraben sierraben is offline
sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.sierraben has a spectacular reputation.
I put a RV cam awhile back in my 352.
I took it out because it had a pretty good lope to it.
Maybe it wasn't an RV cam.
It was a Crane Blazer Cam
Duration: Intake .292---Exhaust .310---Overlap 70
Lift: Intake .528"---Exhaust .546"
Old 08-10-2007, 06:35 AM
Way past an RV grind in my book.
Old 08-10-2007, 09:32 AM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
I'm sure those are "advertised" durations, so take about 50 off and you'll have the "actual" duration. Most cams WITH actual 310 duration have alot more than .540 lift(usually over .600 somewhere). If I recall from back in the day, the "blazer" cam was not an RV cam. Remember back in the 80's when the ads in catalogs said "If you want the baddest sounding car in the lot.........buy the 305 duration cam"
I'm sure it had a "choppy" note to the exhaust, but everyone's idea of what a cam sounds like is different. It ain't a big cam unless the car shakes...not just the tailpipe!! LOL!
Old 08-10-2007, 11:50 AM
PROSTOCK PROSTOCK is offline
PROSTOCK is gaining momentum as a positive member of FTE.
What is an "RV" cam?
"Really Varies" with the cam manufacturer... But I'm pretty sure sierraben's cam would not be an "RV" cam
Old 08-28-2007, 01:15 AM
ford390fe ford390fe is offline
ford390fe is starting off with a positive reputation.
I would say they call it an RV cam because of the low end torque reason. This would be essential in pulling a camper or an RV. That is my guess why it is called that.
RV Cam HP Gains?? on a 302. cchimuk 1987 - 1996 F150 & Larger F-Series Trucks 21 02-23-2013 04:33 AM
Difference between RV cam and comp cam??? Shwan_89HD 1987 - 1996 F150 & Larger F-Series Trucks 18 04-14-2012 06:34 PM
rv cam 460mudtruck Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 08-31-2006 08:36 PM
RV Cam in 351W jarch Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 12-20-2005 01:22 PM
R.V. Cam, what does it stand for? ceetwarrior FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 17 02-10-2004 12:47 AM
Tags
390, cam, cams, camscom, camshaft, camshafts, f100, ford, good, horsepower, rv, stock, trucks, vs, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
