hydrolic fluid - Ford Truck Enthusiasts Forums
hydrolic fluid
Old 08-08-2007, 09:05 AM
tiradebass tiradebass is offline
tiradebass is starting off with a positive reputation.
Thumbs up hydrolic fluid
i have a 1976 ford f-350 1 ton dump truck. what type of hydrolic fluid do i use for the dump bed? i know it's low and i want to top it off but i don't know what kind to use or even where to find it. checking around at local auto part stores didn't help because they didn't know either! if anyone knows please get back to me. thanks!!!
Old 08-08-2007, 09:23 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Welcome to FTE
Contact a BIG truck repair shop, or parts store, tell them who made the system. Ask them for the correct hydraulic fluid.
There may be a metal tag on the system that tells what correct fluid is used.
Old 08-08-2007, 02:15 PM
76supercab2's Avatar
76supercab2 76supercab2 is offline
76supercab2 has a good reputation on FTE.76supercab2 has a good reputation on FTE.76supercab2 has a good reputation on FTE.
I'm guessing the system was probably not built by Ford. So those sources may not be much help. NumberDummy's suggestion is a good one. You really want to get the proper oil. For example, I run case/ingersoll garden tractors. They have a hydraulic drive, (NOT a hydrostatic drive, there is a difference). These tractors run 20W-40 motor oil in the hydraulic system. NOT the red hydraulic fluid. Hydraulic fluid is too thin and the system won't run properly on it.
Look for the manufacturer's tag.
Old 08-08-2007, 03:16 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Welcome to the site.
Maybe check here as this was something Ford didn't Make it was an aftermarket installation
http://www.tpub.com/content/engine/1...s/14105_39.htm
1970 F-700 value cajunhcm Large Truck 6 06-18-2014 09:33 PM
Great Brake invention F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 9 04-27-2014 12:57 AM
Hydroboost leak? armysoopertrooper 1999 to 2016 Super Duty 0 04-16-2012 05:35 PM
I am selling my F350 Mason Dump....what is it worth brianteel 1999 - 2003 7.3L Power Stroke Diesel 0 02-22-2005 09:20 PM
adjustable rockers and hydrolic lifters mamafedmepaintchips FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 12-29-2003 07:57 PM
Tags
1987, dump, duty, f350, fluid, ford, heavy, hydraulic, hydrolic, hydrualics, oil, put, tiradebass, truck, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
