whipple helppp
whipple helppp
OK now that I took care of the spark plugs breaking off in my cylinders.... I'm now able to continue with the SC install..... If any one can help, I'm stuck with this hose which I think is a PCV hose that is located in front of the driver side valve cover.....the hose is the only one that I don't have hooked up to anything and whipple doesn't show where it goes......
Also does anyone have an 04 150 with the 5.4 whippled and has PICS of there break booster set up ... like how it was connected from the break booster then routed after the tee connector along the firewall then somewhere behind the ECU....
Whipple also gave a triangle plate that I'm sure gets used but it doesn't show where it goes.......
If anyone is going to do this install don't use the directions that Whipple will send you, call whipple and tell them you want the pdf file for the 5.4 install. This PDF file will be in color..... The instructions that Whipple sends are in Black and white and the PICS are horrible..... There will be a bunch of places where you will need PICS and you'll get stuck beating your head in..... For me and the 3 other guys helping with my install were beating our heads in trying to picture were some of these hoses were supposed to go...
