speed limiter
speed limiter
First I want to stress it is a real bad idea to be driving around without your seatbelt on, even at legal speeds, to do so at above the posted limits, well you might just have someone drive for you while you jump out of the truck cause you'll be just as well off. Seat belts help do more then many peole think, they can help to keep you in the chair and behind the wheel where your "driving skill" can help you recover from a otherwise "minor" initial impact instead of being knocked out of postion and helpless to do anything before the often more devistating secondary impacts.
Well now, with that done I recommend that you talk to Ken about a "chip" at this sites on-line store. I think he can reset the speed limiter to what ever you want.
As for the pesky seat belt/door ajar/key in the ignition chime just stick your head under the dash, eh with the truck in park, motor off, key in the "on" postion and the door open. You will be able to find the offending chime by following your ears, you can then simply "unplug" this noise maker.
Petrol
Petrol
speed limiter
Not to be a PITA, but why don't you just wear your seatbelt and not drive 100MPH?
Even if you don't like the seatbelt, you'll at least be able to have an open casket funeral when you wreck at 100MPH.
If one were so inclined, you could probably wire a bypass into the wires on the floor (that lead to the seatbelt) to make it think the belt's always plugged in.
As far as the speed limiter, don't be a butthead.
Just my $.02
XXL
Just my $.02
XXL
speed limiter
All you're going to do by exceeding 100MPH in your truck and bypassing or reprogramming the speed limiter is put yourself in danger, others on the highway in danger, and damage your truck. Maybe you don't mind endangering yourself and others, but obviously if you are on this forum you enjoy your truck. You can very easily do all sorts of damage to the drive shaft and other parts of the truck by exceeding the governed speed.
speed limiter
i always drive the speed limit.........?
well .. no .. i dont .. but my f150 does not shut off at 100. 99 with 5.4 only found that out a couple of times. in utah. figured id clean the cobs out.. but yes they make chips and dip for that sort of thing.
the cheapest way to shut off the seatbelt dong.. after starting the truck .. jsut push the release button
no more beep
later yall
brant.
no more beep
later yall
brant.
speed limiter
> BS, going over 100mph will not damage the truck.
The reason that vehicles are speed limited (I know, someone already pointed this out, but I want to go into more depth, not many people know the why's) is because the tires are speed limited. Take a thin piece of metal that you can bend with your hands. Bend it back and forth a few times and feel where you bent it.
It's hot, isn't it?
Now apply this to tires. Look at your tires while your vehicle is parked. The sidewalls bulge where the tires meets the road. As the tire rolls, the sidewall flexes. If the tire is rolling too fast, the sidewall will get too hot and blow out. A blowout at 100mph *will* destroy the vehicle, yourself, and any of your passengers in the process.
So yes, in effect, going over 100mph will damage the vehicle.
BTW, I resent people who put my life in danger because they get off on speeding. You want to race, take it to the track. Not near me, not near my family.
It's hot, isn't it?
