1986 F150 Gas Tank Venting...HELP
I am new to the forum and hope someone can help.
I am having an issue venting my tank as gas is being pumped in to it.
The tank was replaced by a previous owner, then I changed the filler neck, then the venting valve on top of the tank, then the entire fuel filler neck with internal vent tube and it still has not helped. I can't pump more than a few pennies before it shuts off on me. I am at my witts end....
Any suggestions?
They will be greatly appreciated.
Thanks
GIORNO
Any suggestions?
Thanks
GIORNO
Any suggestions?
Thanks
GIORNO
Any suggestions?
Thanks
GIORNO
It's impossible to assist you when the following isn't known:
Flareside or Styleside pickup bed? / Midship or Aft Axle Fuel Tank? / Engine size is?
Different filler necks, type of tank (plastic or steel), different hoses are used depending on location of tank and bed type.
Thanks for the reply.
Here is more info on my truck:
It has a 300 straight 6, styleside 8 foot box, with a midship tank, and a steel filler neck with a rubber hose connecting it to the tank.
The vent hose inside is plastic and I will look for a blockage.
Thanks again for the responses and I thank you in advance for anymore info or advice anyone will share.
giorno
giorno
giorno
giorno
Here the reference for the illustration, a Ford dealer will have the exact same reference, so they can show you what the system is supposed to be.
1980/89 Ford Light Truck Parts Catalog-L/T2 / Illustration Section 90.1; Page 2 (Microfiche 12-02)
muddyoldford
18
05-29-2020 08:07 AM
Kennyhbh
11-30-2016 12:26 PM
dnkensinger
06-07-2016 06:15 PM
Uni Moe
10-03-2015 07:45 PM
Andrew7dg
11-29-2011 10:44 AM
