Go Back   Ford Truck Enthusiasts Forums > Bronco > 1966 - 1977 Early Broncos
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1966 - 1977 Early Broncos SPONSORED BY:
  #1 (permalink)
Old 08-06-2007, 08:01 PM
1976 ranger's Avatar
1976 ranger 1976 ranger is offline
Garage is empty, add now
1976 ranger is starting off with a positive reputation.
Ford 9 inch axle length for early bronco
Does anyone know what the axle length for the 9 inch rear is for a 77 bronco. I bought a 77 9 inch big bearing housing from a 77 bronco And now i have to find axles but dont know the length. Thanks
David
  #2 (permalink)
Old 08-07-2007, 12:36 PM
BoltBuster's Avatar
BoltBuster BoltBuster is offline
BoltBuster is starting off with a positive reputation.
ask this one to the guys on classicbroncos.com......
__________________
67' Bronco
92' F150
  #3 (permalink)
Old 08-11-2007, 10:41 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.RCrawler is gaining momentum as a positive member of FTE.
Order stock length axles for a 76-77...
Jason
__________________
'12 Dodge 3500 crewcab 6.7 HO, Not Stock!!
'93 F350 CC 4wd 7.3 ZF and a ton of miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
Honey badger don't care...
  #4 (permalink)
Old 08-14-2007, 01:28 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
David
1976/77 Bronco WEM & WFR 9 inch axles w/large bearing.
D6TZ-4234-F .. Axle Shaft - RIGHT / 28 spline / 29 11/16" long
D6TZ-4234-G .. Axle Shaft - LEFT / 28 spline / 27 1/4" long
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #5 (permalink)
Old 08-15-2007, 12:00 AM
RCrawler's Avatar
Number Dummy,
Since you are listing lengths, how about the 66-75 big bearing, the 66-73 small bearing and the 74-75 big bearing small brake axle lengths if you could.
Thanks for your wealth of parts information,
Jason
__________________
Tags
9, axle, bearing, bronco, early, f150, ford, housing, identify, inch, length, lengths, rear, shaft, tags, wfr, wfra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
