Help With Turn Signal Switch Wiring
I am hoping someone can provide me with the information I need to wire in an aftermarket turn signal flasher switch to my ’46 pickup truck (converted to 12V). It says “Chieftain” on the chrome plated switch housing. It is designed to attach to a steering column by means of a hose clamp type of mounting. It has a pull-out hazard warning switch below the stalk. On the wiring pigtail there are SEVEN colored wires:
BROWN
BLACK
RED
ORANGE
YELLOW
GREEN
And
BLUE
I need to know which wires go where. The only one I am sure of is the BLUE one which goes to the indicator bulb in the switch (thru a 3-prong flasher unit), assuming one does not have dash mounted indicator lights.
On another vehicle I have a “Grote” brand switch but that one has NINE wires so I can’t use the wiring diagram for it.
Any help you can give is greatly appreciated. I tried looking on the web but my search was futile.
Thanks in advance.
Greg
BROWN
BLACK
RED
ORANGE
YELLOW
GREEN
And
BLUE
Thanks in advance.
Greg
hdunlap
16
11-19-2016 02:36 PM
SocialDistortionFan
07-24-2013 08:15 PM
BBBSS
1999 to 2016 Super Duty
10-06-2011 11:16 PM
