94 F150 windshield trim removal
I bought the regular tool not to $$ and it had how to on removal
There are several coating sealer (not undercoat) for rust Most auto parts have something on shelf.
You get what you pay for the better stuff is like a sealer and base coat in one.
If you do have to put in a patch panel they have apoxy glue for it > I have used to repair before holds well. Good luck
Like lostin90s said there is a special tool i have one its U shaped with a hook on each end im sure you can get ones that look different too. You use it by putting one side in between the windsheild and the trim you slide it until you hit a clip and you have to hold the clip with the tool and gently pull up on the trim it might take a little while to get it but it should come.
Good luck
Good luck
jimbo285
13
08-17-2012 06:24 PM
Kalve
18
03-28-2011 11:55 PM
