Filling Body Seams?
Filling Body Seams?
How many of you filled the body seams? Did you also fill the seams inside the cab? If you filled any of them did you weld fill? or just use body filler? I was thinking of welding mine up since the cab pieces will never again be coming apart the Ol' Henry sectioned them together. Thanks Kurt G. Y-blocks rule.
Thanks, I just bought a used Lincoln weld pack 100 wire-feed upgradeable to mig, but right now I cannot afford the upgrade ($110. without bottle). I figure wite fee should be good enough. If you have a mig you have more experience than I, do you think wire-feed is good enough? Kurt G. Y-blocks rule.
Kurt -
I filled all the seam on my 56. On the outside, I tack welded the seams so they wouldn't/couldn't move under the paint, ground them flush and filled them. On the inside, I did the same thing to the seams over the door opening, over the front glass, and both ends of the dash just to smooth it all.
I used a MIG for all of the welding. I have used the flux core, but mostly on thicker stuff. The flux core, besides being really messy, tends to blow through the thinner gage stuff. Most of the cab parts are 18 gage (.050), so maybe tou'll be alright. But you'll probably want to upgrade to the gas bottle soon after trying the flux core. I did.
Hi, The gas setup will be like going from a pinto to a mustang...(lincoln 100HD)
I welded up the exterior cab seam on the sides of cowl, screws for pass side vent, head seam across the back of the cap, shaved the drip rail and fully welded it too, replaced the small front and rear lower bed side panels and welded them in and also fully welded the rear fenders to the bed side. All was smoothed with filler after that.
Ed
Ed
Tip49
I used the rod to fix the door openings, recontoured the dash near the doors and to close the gap between the rear stake pocket and the bed side when you open the tailgate.
I'm sure I used it in other places but just can't remember at the moment. Just turn the heat and feed down till I could tack it and it wouldn't melt away.
To fill small holes I use a brass plate as a backer then the weld will stick to the metal not the brass. Hope this helps.
Chuck
Chuck
