How to change fuel filter on '04 Explorer? - Ford Truck Enthusiasts Forums
Old 08-05-2007, 11:36 PM
DS02F250 DS02F250 is offline
DS02F250 is starting off with a positive reputation.
Question How to change fuel filter on '04 Explorer?
the wife has 45K on her Explorer now, so I figure it's due for a fuel filter. I bought a replacement at kragan, but not sure how to replace it. Is it difficult, or do I need any special tools or know-how?
Thanks a bunch!
daryl
Old 08-06-2007, 06:26 PM
jasongt06 jasongt06 is offline
jasongt06 is starting off with a positive reputation.
no, you just need the quick release tool that is available at any parts store. It is on the passenger side, near the front door, behind an access panel held on by two nuts.
Old 08-06-2007, 06:29 PM
Thanks! I think I still have the tool from my F250 that should work
Old 08-07-2007, 09:26 AM
gibsonj gibsonj is offline
gibsonj is starting off with a positive reputation.
Sometimes, the quick release tool is anything but quick. Those connectors can be stubborn. Patience is key. I've had good success by pushing the tool into the connector, then while holding it in place, pushing in on the fuel lines. This makes sure the tool has engaged the release so the line can be pulled past the "collar" on the fuel filter.
Remember to de-pressurize the fuel system first to reduce some of the fuel spray. Even then, the fuel filter will still be full of fuel. Once you remove the fuel line from one side of the filter, take a golf tee and push in the filter stub. This will cut back on getting fuel all over when you remove the filter.
Good luck.
Old 08-07-2007, 11:13 AM
rrgone rrgone is offline
rrgone is starting off with a positive reputation.
Good idea on the golf tee, I'll remember that next time I change a fuel filter!
On the Gen 3 Explorers the fuel filter is behind a metal shield plate on the frame cross member just forward of the gas tank. Look at the forward side of the cross member on the passenger side and you'll see it. There's a second plastic shield behind the metal plate you'll have to take off too.
Old 08-07-2007, 09:04 PM
Thanks, all . I got it done today, finally. Went well, but was a bit of a hassle the location of it.
Daryl
2001 Ford Explorer Sport Fuel Filter tank44 Explorer, Sport Trac, Mountaineer & Aviator 2 10-26-2006 08:36 AM
99 Explorer-V8-K&N Cone Filter ? Cobra_Kai Explorer, Sport Trac, Mountaineer & Aviator 1 08-07-2006 06:21 PM
Replace Fuel filter 97 Explorer V8 5.0 Marth Explorer, Sport Trac, Mountaineer & Aviator 4 04-24-2004 08:44 PM
02 Explorer Fuel Filter Location Islander69 Explorer, Sport Trac, Mountaineer & Aviator 0 07-20-2003 02:32 PM
Fuel Filter Replacement on 97 Explorer cotoole Explorer, Sport Trac, Mountaineer & Aviator 2 09-30-2001 11:35 PM
Tags
02, 04, 2002, aviator, change, explorer, filter, ford, fuel, location, mountaineer, removal, replace, replacement, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
