How many miles will 5.4 go? - Ford Truck Enthusiasts Forums
Old 12-11-2001, 11:12 AM
pilot10 pilot10 is offline
pilot10 is starting off with a positive reputation.
I have a new 01 f150 w/ the 5.4 and was wondering what kind of miles people are getting out of the engine?
Old 01-06-2002, 08:19 AM
scraprat's Avatar
scraprat scraprat is online now
scraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud of
Pilot10,I have a 99 250SD I bought in april 2000 it had 13000 miles on it. I carry for work about 800-1200lbs in the back.It now has 93000 on it and it is as strong today as it was when i got it.Just keep up on your PM's it's cheaper that way.
Old 01-10-2002, 12:16 PM
Thanks for the info. I am hoping for at least a couple hundred thousand out of it. I drive around 25-30,000 miles per year and would like the truck to have a good long life after it's paid for(somewhere around September 2006).
Tim
Old 02-01-2002, 03:32 PM
LA_EXPY LA_EXPY is offline
LA_EXPY is starting off with a positive reputation.
I have a 97 XLT Expy 4x4 w/the 5.4L. So far, I have 86,500 miles on it. Back in 2000, I drove it about 25K miles (I used to have a long commute). I've seen post w/other having the 5.4L with over 125K and with no serious problems.
Old 04-23-2002, 10:25 AM
Petrol's Avatar
Petrol Petrol is offline
Petrol is starting off with a positive reputation.
I recently past 150k in my F150 5.4L 2WD company truck without a single problem. None of the infamous "piston slap", "head gasket leak", etc. that seems to get blown way out of proportion.
I have all the regular maintenance taken care of by our company equipment mechanic. I have a pretty heavy foot (I also plain run the H*LL out over her from time to time as well)
I usually get a replacement at about 150k but this one still looks very good so far, still plenty strong, the rest of the truck looks and works close to showroom condition. Might just have to run her longer.
Petrol
Old 04-23-2002, 12:25 PM
Higher miles and no problems. That's the kind of feedback I like to here. Just rolled over 18,000 miles in a little under 8 months so I have a ways to go before the truck is really broken in.
Thanks
Tim
Old 04-30-2002, 03:55 PM
k_krett k_krett is offline
k_krett is starting off with a positive reputation.
I service four trucks at the shop with the 5.4 Triton in them. They are only half tons but the guy pulls cattle and gooseneck trailers with all four of them. They all have around 200,000 to 250,000 miles on them and the only thing they needed were spark plugs and oil changes.
Old 06-26-2002, 07:34 PM
AzPete's Avatar
AzPete AzPete is offline
AzPete has a good reputation on FTE.AzPete has a good reputation on FTE.
I drive a Ford van, E-350 15 passenger for a company that needs employees to be transported 50+ miles to work. The first van we had was a '99 E-350 15 pass. with the 5.4. It got driven 405 miles per day, 7 days per week, 365 days per year. Each run was for about 3 hours. The core of the engine never really cooled down as the reading from the temp. gauge showed on each startup for the run. The maintenance was oil at every 5800 miles/two weeks and fix what broke. The trans was serviced at 80,000, 310,000, and 430,000. Normal things that wear out were done as needed. That van had the following major things go wrong...At 340,000 miles, the alternator died. Got a new one and kept on going. At 472,000 miles, the in-tank fuel pump went out. That was on a Fri. night in a small town. No way to get it on the road so the boss bought me a new '02 and put it in service the next day. We sold the '99 with 472,000 miles on the drive train with only those two breakdowns. Ran 16 mpg to start, got 15 mpg upon selling. Got $8500.00 for it. The rest of the van looked like new. Yep, my new van is the same and my '01 F150 Lariat 4X4 Off Road has the same motor.
Az Pete
Old 06-27-2002, 12:15 AM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
WOW!
Now that is a cool story!
Old 08-30-2002, 02:19 PM
BRONC72 BRONC72 is offline
BRONC72 is starting off with a positive reputation.
I drive all over the country for work . 99 f-150 5.4 triton. 4x4 off road pakg. flare side, shrt bed, ext cab
currenly 120K miles .
relpaced tires , shocks, front rotors/brakes at 100K !!!!!!!!!
then all the other stuff like oil and tranny fluid and diff fluids on time..
runs great..
cut the muffler out .. get about 18mpg now even up to 19 every once in a while .
brant
Old 09-08-2002, 02:57 PM
the4by4freek the4by4freek is offline
the4by4freek is starting off with a positive reputation.
Got 137000 on my 97 Expy with the 5.4. The Da*n thing runs just as strong as a new one! I love it! Getting about 17/19 MPG and no problems. Oil is changed every 3000 miles with 5W30 Castrol non synthetic,just had to put front shocks on it, but it only ran about $35 for Monroe gas matics. Tow a trailer for side business remodeling houses. What more can I say, The thing is awesome!
Old 09-10-2002, 03:40 PM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
Don't forget to change the antifreeze on a regular basis. Even if it tests as having sufficient antifreeze protection, the corrosion inhibiters lose their punch after a couple of years.
Old 10-23-2002, 04:41 PM
screwy's Avatar
screwy screwy is offline
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
[updated:LAST EDITED ON 23-Oct-02 AT 04:43 PM (EST)]hi guys just thought I would chime in, my fathers company has a few e-250 5.4 and these vans run all day every day at about 70mph so we easily do 150000-200000 a year we have a 2001 thatís got about 250000 on it, now for the story on the oil. up until about a year ago we didnít have the greatest maintenance tracking program so thing would get missed (oil changes etc.) and we take all are vans to Indy lube cause we get a better deal than doing it our selfís so anyways they keep records on that so when we took it in one time the records said that it had gone 60000miles!!!!! safe to say I didnít believe it been when they showed me the condition of the oil i was stunned had everyone in the place looking at it said it was the
"worst they ever saw" (still think it was a flaw it the records but that oil was bad if you touched it it would follow your finger like hot glue) so I think its a good engine
P.s. still running sweet
96 Bronco, Eddie Bauer, 351w, auto
Old 12-07-2002, 11:20 AM
cleamon cleamon is offline
cleamon is starting off with a positive reputation.
Mine is a 1997 5.4 and has over 170,000 and I can still outrun most Chevy's!
Old 12-08-2002, 12:18 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
5.4 life expectancy COhunter Modular V8 (4.6L, 5.4L) 56 11-13-2015 07:28 PM
how much is a decent trans for a 06 E350 5.4? tabijan 1968-2013 Full Size Vans 6 07-26-2015 08:54 PM
2006 f150 5.4 huckster 2004 - 2008 F150 0 06-25-2015 03:16 PM
5.4 2v engine swap bubahyde 1997 - 2003 F150 2 06-05-2015 06:38 PM
5.4 runs rough mainefordman 1999 to 2016 Super Duty 9 03-11-2015 11:25 PM
Tags
01, 04, 2001, 54, 54l, f150, ford, fords, gallon, lariat, miles, run, supercrew, triton, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
