Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-05-2007, 06:45 PM
Oakroadjoe Oakroadjoe is offline
Garage is empty, add now
Oakroadjoe is starting off with a positive reputation.
226/tdc
How do i find TDC on no.1 cyl.I want to pull the dist.and be able to put it back in the same spot. Never messed with flatheads before,any help will be great.
  #2 (permalink)
Old 08-06-2007, 04:10 PM
rswhitmore rswhitmore is offline
rswhitmore is starting off with a positive reputation.
One method: Locate No.1 cylinder (I think is is the back cylinder on the 226) and find it's spark plug wire on the distributor. Remove the distributor cap and mark the location of No.1 spark plug wire on the distributor. With the cap off rotate the engine by hand until the timing mark comes up (I believe the 226 timing is set a top dead center), and the rotor is pointing to No.1 spark plug location. If you bring the timing marks up and the rotor is not pointing to No.1 plug wire, then you are on the exhaust stroke rather than the compression stroke. If this is the case, roll the engine through another revolution. Put the distributor back in with the rotor pointing to No.1 plug wire and the engine at TDC on the compression stroke - just like it was when you removed the distributor. There are other methods, but this is simple and it works. Bob
  #3 (permalink)
Old 08-06-2007, 05:40 PM
Snowking's Avatar
Snowking Snowking is offline
1950 Mercury M47
Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.
That sounds all good, but I think your mistaken bout number 1 cylinder. unless the 226 is different from every other Ford motor number one cylinder is the one at the front nearest to the water pump.
__________________
Some nights you just have to realize your gonna be slaying a Dragon and not saving the Princess
  #4 (permalink)
Old 08-06-2007, 10:19 PM
Snowking is right about No.1 Cylinder being the cylinder nearest the water pump.
Bob
Tags
1, 1967, 226, 352, cyl, f100, flathead, ford, location, plug, spark, tdc, timing, v8, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
