stock 2.3 ignition
stock 2.3 ignition
i am going to start racing a stock 4 mustang, ive been reading the posts on here and i havent seen very much about ignition systems, the rules state: stock ignition, so what is the best stock ignition system that came on the 2.3L (prior to the coil packs and 8 plugs)? this will help out alot, if possible i need wiring diagrams also.
Thanks in advance
Thanks in advance
If you want a stock 'points' ignition, you have one choice: 1974.
Duraspark is good, also. Will spin into the high 4-digit range w/o problem, from what I hear.
With the points dist, you can tickle the advance curve as you wish, within limits. The electronic dists, at least the one I have, has room for mechanical advance under the rotor. Some systems lock it in place, (EEC-XX), so check under the rotor before you choose.
tom
tom
The best system is to use the Dura Spark dist, change the advance to the one marked 13, its under the plate. Then wire that to a TFI I module, better spark and reliability.
The system a lot of racers are going to, is the TFI IV system, just three wires to hook it up. Locked timing, no advance, just spin motor before hitting ign switch. Very reliable. Module is mounted on side of dist and has 6 pins, you only need the bottom three for it to work.
Both will perform in excess of 10,000 rpm, more than you will ever need.
Just be sure you have good grounds, block to frame, dist to block etc.
You might also try www.4M.net mini stock tech section.
Thanks in advance
Thanks in advance
http://www.performancedistributors.com/ministock.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
FTE Sponsor
[QUOTE=PerfDistIgnition]You may want to consider our Ford Duraspark Racing Ignition System:
http://www.performancedistributors.com/ministock.htm[/QUOTE]
Wow!!! Kinda pricey for low buck racing. jd
on
When I ran mini-stocks, I used a stock Duraspark system with great success. Be sure to use a module with the blue grommet where the wires come out of it. They're color-coded for different applications and the blue grommet module is the best all-around unit to use. Doesn't matter if it comes off a 4, 6 or 8-cylinder vehicle either. And take a spare one to the track with you.
Primerranger
03-08-2015 10:29 PM
CaptainJack_7
03-04-2015 06:05 PM
picklesf100
06-17-2012 12:21 PM
pknute
Electrical Systems/Wiring
22
02-05-2006 06:06 PM
