Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-05-2007, 06:47 PM
stock4mustang stock4mustang is offline
Garage is empty, add now
stock4mustang is starting off with a positive reputation.
Smile stock 2.3 ignition
i am going to start racing a stock 4 mustang, ive been reading the posts on here and i havent seen very much about ignition systems, the rules state: stock ignition, so what is the best stock ignition system that came on the 2.3L (prior to the coil packs and 8 plugs)? this will help out alot, if possible i need wiring diagrams also.
Thanks in advance
  #2 (permalink)
Old 08-06-2007, 07:10 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
If you want a stock 'points' ignition, you have one choice: 1974.
Duraspark is good, also. Will spin into the high 4-digit range w/o problem, from what I hear.
With the points dist, you can tickle the advance curve as you wish, within limits. The electronic dists, at least the one I have, has room for mechanical advance under the rotor. Some systems lock it in place, (EEC-XX), so check under the rotor before you choose.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #3 (permalink)
Old 08-06-2007, 10:21 AM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
The stock ignitions on the 2.3's with EFI were very good. We use them on turbo's without any problems. Racer Walsh did have a stock coil with a little more output, but I don't know if they still do. For the earlier engines with ignition points, the Duraspark II is good. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #4 (permalink)
Old 08-08-2007, 12:20 PM
Old Rob Old Rob is offline
Old Rob is starting off with a positive reputation.
The best system is to use the Dura Spark dist, change the advance to the one marked 13, its under the plate. Then wire that to a TFI I module, better spark and reliability.
The system a lot of racers are going to, is the TFI IV system, just three wires to hook it up. Locked timing, no advance, just spin motor before hitting ign switch. Very reliable. Module is mounted on side of dist and has 6 pins, you only need the bottom three for it to work.
Both will perform in excess of 10,000 rpm, more than you will ever need.
Just be sure you have good grounds, block to frame, dist to block etc.
You might also try www.4M.net mini stock tech section.
  #5 (permalink)
Old 08-08-2007, 03:21 PM
PerfDistIgnition PerfDistIgnition is offline
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
Quote:
Thanks in advance
You may want to consider our Ford Duraspark Racing Ignition System:
http://www.performancedistributors.com/ministock.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
  #6 (permalink)
Old 08-09-2007, 05:31 PM
[quote=PerfDistIgnition]You may want to consider our Ford Duraspark Racing Ignition System:
http://www.performancedistributors.com/ministock.htm[/QUOTE]
Wow!!! Kinda pricey for low buck racing. jd
__________________
  #7 (permalink)
Old 08-13-2007, 08:09 AM
TigerDan's Avatar
TigerDan TigerDan is offline
1968 Ford F-250
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
When I ran mini-stocks, I used a stock Duraspark system with great success. Be sure to use a module with the blue grommet where the wires come out of it. They're color-coded for different applications and the blue grommet module is the best all-around unit to use. Doesn't matter if it comes off a 4, 6 or 8-cylinder vehicle either. And take a spare one to the track with you.
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
Tags
23, 23l, 89, diagram, distributor, dura, ford, ignition, ignsyst, mini, ministock, points, racing, ranger, spark, stock, tfi, tfiiv, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
