5.4 question plz help
Old 08-04-2007, 07:30 PM
tjpye's Avatar
tjpye
tjpye is offline
is the 2004 f250 5.4 260 hp or 305 im deciding on whether to get this truck or wait until i see a v10 but if it has 305 it will make a big difference
Old 08-04-2007, 10:06 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
260hp. I think the SD trucks got the 3V 300hp engine in 05.
Old 08-05-2007, 11:35 AM
ReAX's Avatar
ReAX
ReAX is offline
I too think that the 3v motor came in the superduties in 05, and the 04 still had a 2v.
Old 08-05-2007, 01:43 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
Correct 3V's started in '05 MY for SD's.
Old 08-05-2007, 03:40 PM
BLK94F150's Avatar
BLK94F150
BLK94F150 is offline
Up to 04, the 5.4 only had 260 HP and more importantly 350ft/lbs of torque. In 05 the HP jumped to 300, but torque only got a 15ft/lb bump to 365. Woop-de-do.
The V-10 up to 04 had 310HP and 425 ft/lbs of torque and the mileage in a Superduty isn't much worse than the 5.4 from reports around here. In 05 it went to around 352HP and 450ft/lbs.
Mike
Old 08-05-2007, 06:17 PM
CounterMaker's Avatar
CounterMaker
CounterMaker is offline
im going to just back up what everyone else said...the 3v came into the in 05... as far as MPG...my dad cant break 11 mpg in his v10 where as i just got 13.5 with mine and that wasnt ven babying it...we drive the same route all week....if you tow heavy loads...yes wait and get a v10, but the 5.4 is a solid motor even though pre-05 models were a little under powered...as a everyday driver and a once in a while tow-rig, the 5.4 is a great little motor...paired with 4.10 or 4.30 gears it would do just fine...keep us posted!!!
Old 08-05-2007, 06:30 PM
CounterMaker
1999-f250/f350 5.4 (2v) - 235hp and 335 ft/lbs
2000-2004 f250/f350 5.4 (2v) - 260hp and 350 ft/lbs
2005-2008 f250/f350 5.4 (3v) - 300hp and 365 ft/lbs
1999-f250/f350 6.8 v10 (2v) - 275hp and 410 ft/lbs
2000-2004 f250/f350 6.8 v10 (2v) - 310hp and 425 ft/lbs
2005-2008 f250/f350 6.8 v10 (3v) - 362hp and 457 ft/lbs
Old 08-05-2007, 08:36 PM
galaxie641's Avatar
galaxie641
That looks like a good old wiki quote, the SD's never had the NPI 5.4L's so the '99 numbers are wrong. Not to mention I have never heard of NPI V10 heads which is what that 275hp number must be trying to say.
Old 08-05-2007, 09:01 PM
CounterMaker
actually i pulled that information off of about 4 or 5 websites...maybe im wrong ... maybe im not but
Old 08-05-2007, 09:03 PM
CounterMaker
from what i understand the 5.4 and 6.8 motors didnt recieve PI heads untill the year 2000..
Old 08-05-2007, 09:06 PM
CounterMaker
Old 08-05-2007, 09:07 PM
CounterMaker
Old 08-05-2007, 09:09 PM
CounterMaker
i can keep going if you want me too...
http://www.cartest.ca/1999_ford_super_duty_f_serie.htm
Old 08-05-2007, 09:12 PM
CounterMaker
https://www.ford-trucks.com/forums/6...for-5-4-l.html
bbender85 has a 99 and he claims he doesnt have pi heads either...maybe hes wrong too...
Old 08-05-2007, 09:51 PM
galaxie641's Avatar
galaxie641
Wow thats one way to pad posts. I stand by no NPI 6.8L's or 5.4L's in SD's.
Quick Reply: 5.4 question plz help
