Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-04-2007, 11:24 PM
stock4mustang stock4mustang is offline
Garage is empty, add now
stock4mustang is starting off with a positive reputation.
Question rods/pistons??
can i put stock 2.3 pistons on 5.7" chevy rods?
  #2 (permalink)
Old 08-05-2007, 03:37 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
No. The pistons will stick out the top of the cylinders. You have to compensate for the extra rod length by moving the pin height in the pistons. Unless you are building an extremely high performance engine, rod length's don't make that much difference, and may not make a difference then. There are a couple of schools of thought on the subject, both pro and con, but no general consensus that I know of. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
  #3 (permalink)
Old 08-05-2007, 06:38 PM
thanks, ive heard people talk about it but i wasnt sure if they were using stock pistons or aftermarket.
  #4 (permalink)
Old 10-09-2007, 07:46 PM
Crossfire Crossfire is offline
Crossfire is starting off with a positive reputation.
Contact Racer Walsh (racerwalsh.zoovy.com). They know as much about 2.3L building as anyone. The Chevy rods needed are the small journal V8 (265/283) or the 250 I6 rods and, no, stock pistons won't work. Longer rods reduce side loading on the cylinder walls, transfer more thrust to the crankshaft and increase piston dwell time at TDC. Personally, I'd go with Racer's stroker crank for 2.5L unless you have the turbocharged SVO motor.
Tags
23, 23l, cylinder, f150, ford, i6, inline, piston, pistons, rods
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
