5.4 question plz help - Ford Truck Enthusiasts Forums
Old 08-04-2007, 08:30 PM
tjpye tjpye is offline
tjpye is starting off with a positive reputation.
is the 2004 f250 5.4 260 hp or 305 im deciding on whether to get this truck or wait until i see a v10 but if it has 305 it will make a big difference
Old 08-04-2007, 11:06 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
260hp. I think the SD trucks got the 3V 300hp engine in 05.
Old 08-05-2007, 12:35 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
I too think that the 3v motor came in the superduties in 05, and the 04 still had a 2v.
Old 08-05-2007, 02:43 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Correct 3V's started in '05 MY for SD's.
Old 08-05-2007, 04:40 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.BLK94F150 has a great reputation on FTE.
Up to 04, the 5.4 only had 260 HP and more importantly 350ft/lbs of torque. In 05 the HP jumped to 300, but torque only got a 15ft/lb bump to 365. Woop-de-do.
The V-10 up to 04 had 310HP and 425 ft/lbs of torque and the mileage in a Superduty isn't much worse than the 5.4 from reports around here. In 05 it went to around 352HP and 450ft/lbs.
Mike
Old 08-05-2007, 07:17 PM
CounterMaker CounterMaker is offline
CounterMaker is starting off with a positive reputation.
im going to just back up what everyone else said...the 3v came into the in 05... as far as MPG...my dad cant break 11 mpg in his v10 where as i just got 13.5 with mine and that wasnt ven babying it...we drive the same route all week....if you tow heavy loads...yes wait and get a v10, but the 5.4 is a solid motor even though pre-05 models were a little under powered...as a everyday driver and a once in a while tow-rig, the 5.4 is a great little motor...paired with 4.10 or 4.30 gears it would do just fine...keep us posted!!!
Old 08-05-2007, 07:30 PM
1999-f250/f350 5.4 (2v) - 235hp and 335 ft/lbs
2000-2004 f250/f350 5.4 (2v) - 260hp and 350 ft/lbs
2005-2008 f250/f350 5.4 (3v) - 300hp and 365 ft/lbs
1999-f250/f350 6.8 v10 (2v) - 275hp and 410 ft/lbs
2000-2004 f250/f350 6.8 v10 (2v) - 310hp and 425 ft/lbs
2005-2008 f250/f350 6.8 v10 (3v) - 362hp and 457 ft/lbs
Old 08-05-2007, 09:36 PM
That looks like a good old wiki quote, the SD's never had the NPI 5.4L's so the '99 numbers are wrong. Not to mention I have never heard of NPI V10 heads which is what that 275hp number must be trying to say.
Old 08-05-2007, 10:01 PM
actually i pulled that information off of about 4 or 5 websites...maybe im wrong ... maybe im not but
Old 08-05-2007, 10:03 PM
from what i understand the 5.4 and 6.8 motors didnt recieve PI heads untill the year 2000..
Old 08-05-2007, 10:07 PM
Old 08-05-2007, 10:09 PM
i can keep going if you want me too...
http://www.cartest.ca/1999_ford_super_duty_f_serie.htm
Old 08-05-2007, 10:12 PM
http://www.ford-trucks.com/forums/63...for-5-4-l.html
bbender85 has a 99 and he claims he doesnt have pi heads either...maybe hes wrong too...
Old 08-05-2007, 10:51 PM
Wow thats one way to pad posts. I stand by no NPI 6.8L's or 5.4L's in SD's.
F 250 tire question JayFan 1999 to 2016 Super Duty 3 11-16-2012 05:33 PM
305 tires?? VONxRUBENxLA 1999 to 2016 Super Duty 2 08-01-2012 02:52 PM
285 or 305 Tires on my 2006 F-250 5.4L 7mag 1999 to 2016 Super Duty 12 03-08-2009 08:18 PM
Tires for a F250 Keepitrunnin 1999 to 2016 Super Duty 4 11-30-2007 10:12 PM
4.2-5.4l tonyyayo305 1997 - 2003 F150 3 02-17-2006 01:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
