AOD Governor...
Old 08-04-2007, 03:02 PM
Rbomar's Avatar
Rbomar
Rbomar is offline
AOD Governor...
My 1988 F150 4X4 w/AOD won't shift out of first gear and I wanted to check to see if the governor was stuck but I do not know even where it is located or what it looks like. Could someone help me find my governor? Thanks!
Old 08-04-2007, 03:57 PM
rclarke's Avatar
rclarke
rclarke is offline
The governor is mounted on the governor collector which is on the output shaft inside the extension housing. With the extension housing off the transmission it is a very easy removal. 2 philips head screws and its in your hand. Pay attention to the valves inside so you can reinstall them properly. Now the bad news, if the governor is stuck the only thing I have seen cause it is a failing transmission with trash in the oil. Before I even pulled the governor for inspection I would drop the pan and look inside. If there is much trash in the bottom of the pan you might just as well pull the transmission for overhaul. If the pan is clean put a new gasket and change all the oil (drain the torque converter) and clean the governor and hope for the best.
One other thing can cause no upshifts, the throttle pressure rod or cable could be stuck in a WOT position. In that case it might just be a matter of freeing up the cable or rod.
Old 08-05-2007, 10:42 AM
stuart1's Avatar
stuart1
stuart1 is offline
In a 4x4 the transfer case must be removed to gain access to the governor.
Check the throttle cable first.
Quite often the bushing on top will break.
If there is no control over throttle pressure the transmission will not shift.
Old 08-05-2007, 02:44 PM
rclarke's Avatar
rclarke
rclarke is offline
"In a 4x4 the transfer case must be removed to gain access to the governor."
Right on, I missed that it was a 4x4.
scrobbie
01-18-2014 06:12 PM
bbf150
17
06-15-2013 01:55 PM
RAGaz
Modular V10 (6.8l)
06-18-2007 12:03 AM
Craigwell
02-14-2007 06:53 PM
khelms_98
1997-2006 Expedition & Navigator
03-16-2004 11:55 PM
Quick Reply: AOD Governor...
