Forgot ONE bolt in Valve body-big deal?
I removed my accumulator valve body today to install some TransGo springs and valves. After I had it all back together with fluid in it I noticed a valve body bolt on the bench. Is it a big deal to not put the bolt in? I will drop the pan and put it in later, I was just curious if there's a reason I can't just forgo it right now.
It's only a big deal if you take the truck out of park. As long as you don't try to move it it's not a big deal.
It is possible that it won't cause a problem, but it's more likely that it is going to cause a leak from one hydraulic circuit to another. This can cause one or more clutches to slip, and that means a rebuild.
No reaming involved, but there was a couple small holes I needed to drill in the vb casting. Also, it came with a calibration plate that goes between the vb and the gasket, that had several holes I needed to resize. Altogether, a pretty simple procedure, I was just hesitant since I've never done it before. Now that I have, I would definitely do it again. BTW, I have a bunch of parts left that go in the main vb, I will sell if anyone's interested.
