Vacuum or mechanical secondaries?
Can anyone give me some advantages and/or disadvantages between vacuum secondary 4bbl's and mechanical secondary 4bbl's? I'm in the market for a holley 650cfm, and I've always used mechanical, however, I'm being told I should use vacuum for this particular application. So I'm curious what differences there are, and what effects they have on performance. Also, are vacuum secondaries adjustable? Thanks in advance!!!
SteveT
SteveT
Vacuum operated is definently more streetable! The secondaries will only open when intake pressure dictates that it is needed,and,yes it is very adjustable with different springs available.Mechanicals are better for radical engines above 5,000 rpms.
Phillip
Phillip
Guest
Posts: n/a
