Door sticker tranny code Q ?? - Ford Truck Enthusiasts Forums
Old 08-03-2007, 10:08 AM
Scott109 Scott109 is offline
Scott109 is starting off with a positive reputation.
Hi everyone, My 2006 F-150 XLT 4X4 has tranny code Q. I did not see that letter on the door sticker decoder on this site. Does anyone know what tranny this is? Or could point me in the right direction to find it? Thanks!
Old 08-03-2007, 11:01 AM
Never mind, I found it.
Model: 4R75E
Type: Four speed, Rear wheel drive, and 75(x10)lbs of torque
Years: '04-'07 F-150
Engines: 5.4L
Display: PRN(D)21 w/ overdrive lockout switch
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: B ('04-'05), Q ('06+), F ('06+ Mark LT)
Old 08-03-2007, 11:08 AM
KevinM KevinM is offline
KevinM is starting off with a positive reputation.
Q= 4-speed automatic, 4R75E
Electronically Controlled 4-speed Wide-ratio Automatic Overdrive Transmission (E-Series and F-150)
Transmission code 4R75E
Major features and benefits:
+Robust drive gear and friction materials
+Torque converter provides impressive launch performance and efficiency
+A turbine speed sensor produces improved transmission control and provides the basis
for the fully electronic shift scheduling
+Microprocessor speed improves responsiveness and precision of the control system
+"Smart" fully electronic shift scheduling coupled with the Electronic Throttle Control (ETC) technology calculates torque in the next gear and regulates shift points based on vehicle's projected performance in the next gear
+Overdrive lowers engine rpm at highway speeds, contributing to improved fuel economy
+Adaptive pressure control maintains consistent shift response and feel over time
+Sealed case with lifetime transmission fluid
Driver door jamb sticker. rlacan71 1987 - 1996 F150 & Larger F-Series Trucks 9 09-09-2014 10:47 AM
1995 f250 codes cole96 1987 - 1996 F150 & Larger F-Series Trucks 3 02-02-2009 05:47 AM
1993 F150 Door sticker tranny code "T" handyfiremedic Clutch, Transmission, Differential, Axle & Transfer Case 2 01-18-2008 09:39 PM
04 FX4 Tranny code - Huh? CMOS 2004 - 2008 F150 12 12-20-2005 05:23 PM
Transmission code D renoduckman Ranger & B-Series 4 10-28-2004 08:40 PM
Tags
1987, 2004, code, decode, decoder, door, f150, ford, jamb, pillar, q6, sticker, trans, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
