Have a Volare front clip in our '55 Effie. What is the procedure for adjusting the torsion bars ? So far just tried taking out the slack and tightening X amount of turns. Thanks, Joe
What is it you are trying to do? Jacking the front end of the truck off the ground, supported by jack stands, tightening the left nut will raise the right side of the truck, and vice versa. Loosening will lower. Does that help?
Leave some travel between your front stoppers. I got about 1 1/2 of travel. Been cruising like that for couple of years. Front bumper 7 inches off the ground. Doesn't take much to cause alignment problems.
I just love big windows. I wish I had the skill to put the BW kit in my 55. I gotta be honest tho.. I absolutely love the 55-59 Chevy's too. The front end of those trucks is beautiful! LORD, I APOLOGIZE FOR THAT THERE, AND BE WITH THE PYGMIES IN NEW GUINEA.AMEN
I have to bring this up again.i forget.
Do I tighten the screws to lower the truck or do I loose them,
I had the volare too low and I want to raise it a bit so I cranked the bolts/screws loosing them and the truck got lower.
So which is it.
Thanks guys
