2001 F250 Fog light question - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-02-2007, 09:13 PM
caneintn caneintn is offline
caneintn is starting off with a positive reputation.
I just purchased a 2001 F250 PSD. The previous owner had installed this ranchhand bumper http://ranchhand.com/frontbumpersummit.htm . He did not reinstall the fog lamps and they did not come with the truck. I have found some aftermarket lights that will mount in the bumper and will work well. My question is about the wiring. The exisiting wiring for the factory lights is still ther. They have what appears to be a 2 pin clip that I assume would have attached to the factory lights. Can I tap these wires for the aftermarket lights and have them work with the factory pull out portion of the light switch?
Thanks
Old 08-02-2007, 09:14 PM
BlackF350rocks's Avatar
BlackF350rocks BlackF350rocks is offline
BlackF350rocks is starting off with a positive reputation.
Yup.>>>>>>>
Old 08-02-2007, 09:17 PM
yamaguy's Avatar
yamaguy yamaguy is offline
yamaguy is gaining momentum as a positive member of FTE.yamaguy is gaining momentum as a positive member of FTE.
as long as they are not high voltage lights I think it would be fine.
Old 08-02-2007, 09:23 PM
Thanks for the response. That will make this a quick install tomorrow night.
Old 08-03-2007, 08:33 AM
Ed in Maine's Avatar
Ed in Maine Ed in Maine is offline
Ed in Maine is starting off with a positive reputation.
Yes, will work fine. I would do the mod that allows you to turn on the fog lights with only the running lights though. As the switch is right now on the 2001, you have to have the lights all the way on in order to get the fog's to come on. Do a search and you will find the mod. There are a couple different ways to do it.
update front end/f250 bumper jazz77 Excursion - King of SUVs 4 12-13-2010 05:22 PM
1985 F-250 Aftermarket Bumpers/brushguards Brands Glockem45 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 06-09-2008 02:11 PM
HELP! TailLights not Working.. StrokeR_7.3 1999 - 2003 7.3L Power Stroke Diesel 3 03-20-2008 10:16 PM
Please recommend a good dually rear bumper Big Sky Rancher 1999 to 2016 Super Duty 4 04-09-2007 11:51 AM
What is your favorite bumper replacement? TERMN8R Excursion - King of SUVs 8 10-30-2005 08:52 PM
Tags
01, 2001, 250, dig, f250, fog, foglight, ford, lamp, lamps, light, lights, mod, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
