Hydraulic fluid?
I run used ATF and hydraulic oil, ISO 32 and 46 regularily. I have probably 30,000 mile on the stuff. I service air compressors for a living and collect large amounts of these oils. The only modification I've done is to install a filter prior to the fuel pump . I also use only my front tank for hydraulic oil..
I have no drivability issues, smoke or other difficulties. I also have 190,000 miles on the odo.
Originally Posted by Red Monkey
Just wondering, have you ever been stopped by the DOT for a fuel check? ATF is red as is off road diesel, I'll bet you would have to do a LOT of fast talking to keep from getting a ticket for illegal fuel with red ATF tinted fuel.
Sorry, just hate taxes...
I've been thinking of finding one of the old military multifuel engines (like the 3 cyl. Detroits used in the old Gama Goats) and putting it in a small truck chassis. Those things were designed to burn anything flammable, as long as it had some lubrication quality. Engine oil, gas (with some oil added), fryer oil, hydraulic oil, brake fluid, didn't matter. It'd burn it.
