'94 Ext Cab 2wd level kit? - Ford Truck Enthusiasts Forums
Old 08-02-2007, 08:10 AM
Georgia F150 Georgia F150 is offline
Georgia F150 is starting off with a positive reputation.
Hey fellas. Does anybody know first hand a shop or a mechanic in SWGa that will talk to me about a leveling my '94 2wd F150? I can't stand the rake I roll with and with bow season around the corner, I don't want to get on the old loggin roads with the nose as low as it is again. I just need the front lifted about 1.5 or 2 inches..Not taller than the rear, but close to equal.
I have spoke to an alignment shop about putting F250 (1994) springs in the front of my truck, but they said that I would never get it aligned if I do (twin I-beam)...Now since he said that, I'm not going back to him to install anything or convice him that he can. Cause obviously he's never aligned a lifted Twin I-beam 2wd...So I spoke to a buddy who is an ASE mechanic..he basically said the same thing...
Well, I guess I need to ask if it can be done, and still be able to adjust the camber?
Thanks
Old 08-02-2007, 10:12 AM
netscaner netscaner is offline
netscaner is starting off with a positive reputation.
Can you just go bigger tires and rims in the front ??
Being you're two wheel drive shouldn't bother anything.
Old 08-02-2007, 02:41 PM
Sorry but No...I have stock wheels however, the tires are the biggest that will fit. I need to lift the front.
Old 08-03-2007, 11:28 AM
Ok...........Has anybody used ANY leveling device on a twin I-beam 2wd truck? If so, what was used, and who made it...Was alignment a problem?
Figured I'd pose the question a little different.
Old 08-03-2007, 01:35 PM
geo455 geo455 is offline
geo455 is starting off with a positive reputation.
I just replaced the front springs in my 94 F150 and it sits perfectly level now. The camber is off slightly (top of tires leaning outward, need to look hard to see it) but even the new springs will settle eventually. The part number I used was for both the F150 as well as the F250. Reference PN FCS824V if you do decide to change out the springs.
John
94 F150 s/cab 5.8/E4OD 3.55LS 2wd
Old 08-03-2007, 03:22 PM
Quote:
John
John, thanks for the reply. I believe your springs are different than mine because of your motor size. I have a 5.0.....
But, other than a different weight requirement, I don't know how much difference there is between our trucks.
I have 185,000 on my truck. And I'm sure these are the original springs. How many miles did you have on your set?
Old 08-03-2007, 03:36 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
You can get the adjustable camber bushings through Bronco Graveyard, I am thinking about leveling out my 96 2wd also.
Old 08-03-2007, 03:43 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
You can put about a 2" lift on the front of the truck before you need to use drop brackets to compensate. A good alignment shop will know how to correct the camber using degreed bushings.
F-150 and F-250 (2wd) springs are different. Different spring rate, slightly longer. They will work, but you will still need to use different bushings. They will also make your truck ride a lot harsher.
Old 08-03-2007, 08:46 PM
My truck has just over 126k. The replacement springs had two more coils on them. Yeah didn't think about engine size...
Old 08-06-2007, 12:01 PM
Ok Andy.. you say I can go maybe 2 inches...How should I go about the lift? F250 springs, or is there another way? I want something solid, but it won't hurt the truck in the long run..Thanks
Ron
Old 08-06-2007, 01:40 PM
andym's Avatar
F-250 spring are going to make it ride really rough.
There was a user here who did it, I remember reading the thread in the last year. Have you tried a search?
Old 08-06-2007, 04:16 PM
Yea man..been searchin, but I get a million different threads with a bunch of unrelated issues....I'll keep trying.
Thanks for the help.
Old 08-06-2007, 04:46 PM
TheRoadVirus TheRoadVirus is offline
TheRoadVirus is starting off with a positive reputation.
I have the front of my truck level with the rear and it's a 2wd. It was done by the previous owner but he said it was done with big block springs as opposed to the smallblock ones? Does that make sense? I do have alignment issues, though. The top of the tires are also very slighty outward, it's not noticeable, but my tires do wear unevenly =(. Hope this helps.
Old 08-06-2007, 09:39 PM
Pkupman82's Avatar
I have been thinking about doing a spacer lift rather than changing springs. I like how my truck rides and would hate to make it make it into a "buck board". I know Daystar makes a 2" spacer lift for 4wd F150s and Broncos, I am wondering if they could fit a 2wd.
Old 08-06-2007, 09:50 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
go to www.rockauto.com
load in your info and look up the springs
there is a lot of info on differant springs
load and unload height and some spring rates
this will give you a starting point
you can also check out differant springs depending on differant engines
I-Beam Drop Brackets Wbrann51 1999 to 2016 Super Duty 0 01-06-2017 01:40 AM
front end alignment killer608 1999 to 2016 Super Duty 4 09-24-2015 10:13 PM
Alignment Numbers: Can I drive like this? DSN46 1999 to 2016 Super Duty 5 02-22-2013 09:10 PM
Dropping I beams with a 2 inch leveling kit? Kohomofo 1999 to 2016 Super Duty 2 02-08-2013 04:31 PM
Raising the front of a twin I-beam F250... quehele 1973 - 1979 F-100 & Larger F-Series Trucks 13 03-02-2005 08:36 PM
Tags
2wd, 4x4, 90, 94, bed, bushings, cab, camber, ext, f150, fcs824v, ford, front, kit, level, replace, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
