burnout
Old 12-19-1999, 05:53 PM
BOB01
Guest
Posts: n/a
burnout
i have an 84 f150 with an 300 6 and a manual 4 spd tranny. i was wonder how you would do a burn out with this truck. thanks
Old 12-19-1999, 05:55 PM
Trail_Rider's Avatar
Trail_Rider
Trail_Rider is offline
burnout
Are you serious......?!?!?!?!?!?!
Old 12-19-1999, 08:05 PM
Jay's Avatar
Jay
Jay is offline
burnout
If you get some high octane gas and dump it in the seat, while smoking, its the only burnout you'll ever see in that truck
Old 12-19-1999, 10:00 PM
Ben_E's Avatar
Ben_E
Ben_E is offline
burnout
Rev it up to about 3500 or more and dump it.
Old 12-20-1999, 07:14 AM
Chuck P.'s Avatar
Chuck P.
Chuck P. is offline
burnout
Just take a window washing fluid bottle with pump and install the lines over the rear tires, run a toogle switch so when you want to do a burn-out(why?), just "juice" the tires to break them loose, this puts on quite a show when the water/bleach or whatever turns to steam. Chuck P.
Old 12-20-1999, 01:57 PM
adam's Avatar
adam
adam is offline
burnout
i have a 89 ford f150 with the 300 with automatic and it will do a burn out! several ways to do one. these trucks have plenty of power. 1 put it in neutral and rev it up then drop it. 2 leave it in gear and floor it. 3 put it in reverse and back up a little ways the ease it in to neutural then dirve and floor it. octane booster will help!
Old 01-02-2000, 01:35 AM
Rockstar's Avatar
Rockstar
Rockstar is offline
burnout
I used to have the same truck as you what I do is put it in 2nd get going about 15mph crank your wheels in some direction and floor it and hit your brakes at the same time it should light them right up or your common turning tire is the passenger pull to the side of the road on gravel or sod pop your clutch floor it and ride your brakes steer back on to the black top and the smoke should fly....I have a 87 now with the 300-6 and the 4 speed its the same way.
Old 01-02-2000, 02:11 AM
Trail_Rider
burnout
Can I get you guys to buy my tires?
Trail Rider
Old 01-08-2000, 08:51 PM
BigBrownTruck's Avatar
BigBrownTruck
BigBrownTruck is offline
burnout
Do this in front a cop that has fresh hot coffee, you get more points for this.
Old 02-04-2000, 07:46 PM
Larry619's Avatar
Larry619
Larry619 is offline
burnout
If anyone can answer this.... Isn't what he suggested bad for the engine? I'm not big on engines and stuff but i can tell you this... I have the same (1993 300 I6) truck and did that once or twice when i started driving it. I stopped because of two reasons. 1) my friends told me it was bad. and 2) it makes the most horrible sound when you do it. It sounds painfull... seriously... i wanna take care of my baby!
please let me know to what extent the damage could be done by doing this stunt?
Old 02-04-2000, 08:27 PM
micah's Avatar
micah
micah is offline
burnout
Well, if just "punch it" and the tires break loose, all you're hurting are your tires. Now the other stuff (like a reverse-drop or a neutral-drop) can be hard on everything between the engine and the rear tires. (Do too many reverse drops in a front wheel drive car and you'll be sorry.) Basically, you're applying extra stress to places that already take alot of beating as it is; like universal joints and rear end gears not to mention your clutch or juice-box.
Old 02-08-2000, 02:40 AM
mocky's Avatar
mocky
mocky is offline
burnout
not trying to be rude but, get a posi rear, a v-8, and a brain.. anybody can do a burnout its all in the technique,i can smoke'em off pretty good myself,(i'll show you my tire reciepts) i have a 71 f100 sb 302 3spd. on the floor, im putting a posi in this spring cause #1 gotta have posi., #2 one tire burnouts are lame! the best way to do the burnout in my opinion is tach it up to about 3500rpm or so(nothing crazy now)let the clutch fly and then lightly(i said lightly)apply the brakes to hold the vehicle still (so you dont roll forward) if you do this right you can hold her there all day if you want to... now this doesnt work on front wheel drive cars but we aint talking fwd here.. good luck and dont let the nice officer catch you doing this(ha-ha)
Old 02-08-2000, 06:33 PM
bigblockhead's Avatar
bigblockhead
bigblockhead is offline
burnout
Put your heel on the clutch and toe on the brake. Let off the clutch while still holding the brake and giving it gas. Thats the way that I thought everyone did it. Also works good when at the top of a hill at a stoplight so you dont roll back into the guy behind you. Practice makes perfect.
Old 02-13-2000, 11:33 AM
LoveMy300's Avatar
LoveMy300
LoveMy300 is offline
burnout
300 and a four speed, you should be able to break them free at will in first or second gear. As to why you want to do this intentionally......
On low traction situations, Ill often start in granny just to avoid spinning the tires. Don't believe the v-8 guys who think a 300 is a joke, just put in a call to clifford performance, spend a couple grand, and show the 302/351 guys whats up with the 3.98 " stroke in that puppy. TORQUE
Old 02-19-2000, 01:28 AM
mocky's Avatar
mocky
mocky is offline
burnout
i may have told him to get a v-8 but i didnt say there was anything wrong with the 300 i-6 motors, i had a 1980 econoline 100 w/a 300 and could smoke'em with the best of them, but nothing and i mean nothing sounds or says im a bad **** like lettin'em rip with a real loud,fuel gulppin,carbon monoxide belchin,attentoin gettin, v-oh my lord-8. thanks i needed that,we have so much snow here i cant stand it.it has snowed at least once a week for a month,one week twice w/multiple inches,and it snowed again today,4 more inches,oh thank you oh great snow god, i needed to vent, bring on the spring & summer so we can cruise and smok'em some more.....
Quick Reply: burnout
