99 E250 bit of a rod knock - heavy oil? - Ford Truck Enthusiasts Forums
Old 08-01-2007, 05:44 PM
Rmvr53 Rmvr53 is offline
Rmvr53 is starting off with a positive reputation.
can I run a non-synthic 20-50 to tone down the "knock"...and yes it is a rod knock - 5.4l with 120k
Bill
Old 08-01-2007, 07:17 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
If you live in a cool climate, I would say no. During the summer or when the low is 70, it should work. However, I'd suggest trying a qt of lucas oil stabilizer first.
Old 08-01-2007, 07:53 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Why not just run 5w50 and be done with it? Unless you live where it never gets below about 60* that oil is way too thick for these engines.
Old 08-01-2007, 08:10 PM
Quote:
who makes a 5w-50?
Old 08-01-2007, 08:13 PM
bigblock_drock bigblock_drock is offline
bigblock_drock is starting off with a positive reputation.
so when u have a defintite rod kncok what do u want to do thicker or thinner oil?
Old 08-01-2007, 08:17 PM
ReAX's Avatar
mobil one has 5w-40
valvoline goes to 20w-50 and 15w-40
Royal purple does SAE 5W40 12-Quart Case* 12540
those are the only brands I consider for oil.
Old 08-02-2007, 06:08 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Quote:
And how does a "stabilizer" help a rod knock?
I know two different people who used that stuff in their motors and developed rod knocks AFTER using it. One was an I6-300 that spun a main, and the other was an old tired 180K+ 351W - it lived for a while. The I6 did not. And in both motors, it was within a week of the oil change and Lucas.
Is it a 3-valve 5.4L? Or an older 2-valve? The 3-valve has a TSB out for a "knock" - cam phase sensor?
Old 08-02-2007, 06:20 PM
as far as I know a 2 valve. Nothing I have paper wise says otherwise. I had a similar experence with Lucas. In this motor. Started the rod knock AFTER using it - took about 2000 miles but its a knock.
Bill
Old 08-02-2007, 07:41 PM
Krewat's Avatar
Quote:
Gee, what a coincidence.
Most of their other stuff people have had lots of luck with it.
But the "stabilizer" ... I don't know - maybe it shouldn't be just poured into the valve cover in one shot or something, but now besides just those two I spoke of that I had direct knowledge in (and diagnosed the knock), there's you and a few others on this site.
Old 08-02-2007, 08:13 PM
ReAX's Avatar
He asked about heavier weight oils, the Lucas stabilizer makes the oils tackier (I don't know specifically what it does to viscosity.) I have used and loved it in my 351m and 300I6, particularly when the 300 was using Mobil 1. I added a qt during oil change and never had any issues.
Old 08-02-2007, 08:57 PM
it may be just that...a coincidence. My son-in-law swears by the stuff but in the two I put it in within about 1500-2000 miles I started to have a knock. Drained the current oil (with Lucas) then went to a heaver oil and the problem went away.
The real question I was asking tho is about using a dino oil vs synthetic in a 5.4 mod motor. Dos it make a difference?
Bill
Old 08-02-2007, 10:08 PM
ReAX's Avatar
I didn't notice any difference between Mobil1 and Royal Purple in my 5.4.
Old 08-02-2007, 11:03 PM
aren't both of those synthetic?
Old 08-04-2007, 10:16 PM
73F100*8Mile 73F100*8Mile is offline
73F100*8Mile is starting off with a positive reputation.
Bill
You're sure sure its a rod knock? 5.4's are noted for having prob's w/ worn thrust bearings. Does the knock go away when you put it in gear? If so, worn thrust bearing.
Old 08-04-2007, 10:28 PM
ReAX's Avatar
Yes, but that's the only change I have made in the last few years.
When I started driving, I changed from pensoil to valvoline and I felt a change, and then in my 89 I switched from valvoline to mobil1 and felt an equal change. However, that's been years ago.
1999 v-10 knocks WARNER757 Modular V10 (6.8l) 2 12-07-2014 09:04 PM
Rod Knock scoutpup99 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 13 02-08-2010 07:08 PM
97 5.4 Engine Knock alloro Expedition & Navigator 3 06-15-2008 02:41 PM
Rod and main bearing? Just changed but motor still knocks? allen410 1987 - 1996 F150 & Larger F-Series Trucks 6 12-06-2004 04:15 PM
engine knocks , rod & or main bearings J&B FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 20 07-06-2004 06:44 PM
Tags
1999, 2006, 351w, e250, ford, gear, heavy, knock, knocking, lucas, oil, rod, sensor, stabilizer, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
