99 E250 bit of a rod knock - heavy oil? - Page 2 - Ford Truck Enthusiasts Forums
Old 08-05-2007, 12:00 AM
Rmvr53 Rmvr53 is offline
Rmvr53 is starting off with a positive reputation.
Quote:
Originally Posted by 73F100*8Mile
You're sure sure its a rod knock? 5.4's are noted for having prob's w/ worn thrust bearings. Does the knock go away when you put it in gear? If so, worn thrust bearing.
very sure its a rod knock...increase in noise under load
1999 v-10 knocks WARNER757 Modular V10 (6.8l) 2 12-07-2014 09:04 PM
Rod Knock scoutpup99 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 13 02-08-2010 07:08 PM
97 5.4 Engine Knock alloro 1997-2006 Expedition & Navigator 3 06-15-2008 02:41 PM
Rod and main bearing? Just changed but motor still knocks? allen410 1987 - 1996 F150 & Larger F-Series Trucks 6 12-06-2004 04:15 PM
engine knocks , rod & or main bearings J&B FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 20 07-06-2004 06:44 PM
Tags
1999, 2006, 351w, e250, ford, gear, heavy, knock, knocking, lucas, oil, rod, sensor, stabilizer, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
