Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
  #1 (permalink)
Old 08-01-2007, 08:44 AM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Garage is empty, add now
Beachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to allBeachbumcook is a name known to all
Shell To Launch 5W-40 / CJ4 Spec'd Oil In September or October 2007
Emailed Shell as to an update on upgrading their current 5W-40 synthetic motor oil to the new CJ4 oil spec? I personally use Rotella-Syn due to availability and price and have always liked the easier cold starting benefits and better high heat protection... but everything I have read is that the CJ4 oil spec offers better viscosity protection and less wear than CI4 (one spec compared to the other).
Here is the email reply I received from Shell this AM...
Jeff, we plan on introducing Rotella T Synthetic 5W-40 CJ-4 around September/October of this year. Thank you for your interest in Shell products.
Richard Moore
Staff Engineer
Shell Global Solutions (US) Inc.
Westhollow Technology Center, PO Box 4327, Houston, TX 77210, United States of America
1-800-231-6950
Guess this makes sense as it will become available prior to the start of the cold winter season? I have always wondered what kind of oil users of the new 6.4L motor would use if they needed, or wanted, a 5W-40 oil like many of 6.0L owners use?
I will be the first to change over from my current CI4+ to the CJ4 when available.
__________________
03 Excursion 6.0L PSD
Magnafine P/S Fluid Filter
Racor By-Pass Oil Filter System
Dieselsite Coolant Filter
Bilstein Shocks/Rancho Steering Stabilizer
Fumoto Oil Drain Valve
BriteBox Headlight Module
Marinco AC Block Heater Plug
24" Wiper Blades
Window Screen - Radiator Bug Shield
Pioneer Airware XM Radio
  #2 (permalink)
Old 08-01-2007, 10:35 AM
satcom40's Avatar
satcom40 satcom40 is offline
satcom40 is starting off with a positive reputation.
Hey Beach I what to switch to syn for the winter this news sound good. Thanks for the update.
__________________
04 F-250 SD 6.0L XLT EC SB Black, May 04 build. Bypass filter for Oil & Coolant, Remote start, Pre-Post Luber, Scan Gauge, 46 gal fuel tank, Boost & Pyro.
  #3 (permalink)
Old 08-01-2007, 01:23 PM
a-rod's Avatar
a-rod a-rod is offline
a-rod is gaining momentum as a positive member of FTE.a-rod is gaining momentum as a positive member of FTE.
After running hot shots secret for 4k Im now running the rotella syn 5w-40, and plan to keep running it. Like Beach has said this synthetic seems to be the best for these motors and injectors.
__________________
Adam. Collision Tech. 2002 7.3 80,000 miles. DP-Tuner, Riffraff FRX - AIH delete, HPX. wicked wheel. 6637. banks power elbow-4inch exhaust. CCV. Foil delete. 6.0 trans/intercooler. Isspro gauges. True-Trac, 2008 mirrors, tailgate, taillights, bumper, diff cover.
  #4 (permalink)
Old 08-01-2007, 05:32 PM
Powerstroke_wannabe Powerstroke_wannabe is offline
Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.
Great news Beach. I've been wondering when the new CJ-4 spec would be available in Rotella's 5W-40. I'll be needing an oil change in late September. Hope it's on the shelf by then.
__________________
Frank
2006 F250 Lariat FX4, CC, SB, 6.0 PSD, Torqshift, 3.73 LS, Backseat DVD system, Extreme Bedliner, Westin Bully Bar, Dieselsite Coolant Filter, Fumoto Valve, Accufab Intake Elbow, Bilstein HD Shocks, Smitty-Bilt Grille Inserts, MBRP Turbo Back Cool Duals (Kitty ran away), ICON Dual Steering Stabilizer Kit w/Bilstein 5100 Shocks, Nitto Terra Grappler AT 295/70-R18, Retrax Cover
  #5 (permalink)
Old 08-01-2007, 06:58 PM
Super08's Avatar
Super08 Super08 is offline
2011 Ford F-350
Super08 has a great reputation on FTE.Super08 has a great reputation on FTE.Super08 has a great reputation on FTE.Super08 has a great reputation on FTE.Super08 has a great reputation on FTE.
Jeff thanks for the info, I still remember reading your old post when you were trying to find out about it. You going to do a VOA on it??
__________________
2011 F350 CC SB Lariat 6.2 4WD 4.30's
  #6 (permalink)
Old 08-01-2007, 07:15 PM
Got Diesel?
Quote:
Hey now... point of clarification.....
I never stated it was best... ever....
I just have stated it is what I use due to availability and price.
Mobil, Shaffers, Chevron and a few others all make quality oils and I am sure that their 5W-40 versions are just as good???
For me... Rotella-Syn works... that's all I have ever stated and my oil analysis reports state the same.
__________________
24" Wiper Blades
  #7 (permalink)
Old 08-02-2007, 08:52 AM
Rob.D's Avatar
Rob.D Rob.D is offline
Rob.D is starting off with a positive reputation.
At what mileage is it considered safe to switch over to synthetic? I have about 9000 on my rig.
__________________
2006 F-350 6.0 PSD,XLT,CC,FX4,LB, Tow Command, Camper Package, Wet Okole Camo Covers, Upfitter Switches, High Idle Mod, Line-X, ARE Z Series Cap, Power Elbow, Dieselsite Coolant Filtration,Oil Guard Filtration, 4" Magnaflow straight pipe, 08 Mirrors, B5+DK, Magnefine PS filter,BD CCV,Spartan Phalanx, 08 tranny pan+filter, 285/65R18Nitto Grappler M/T on Ballistic Hostel wheels,Blue Fuel Spring
  #8 (permalink)
Old 08-02-2007, 11:35 AM
Got Diesel?
Quote:
No one can say or knows....
Some state (as many oil manufactures) that you can switch right away.
Others state to wait for one or two oil changes....
Others state to wait until 10,000 miles to ensure seating of the rings and such...
Diesels take longer to break-in and unless one needs synthetic for cold weather benefits, I tend to go with the 10,000 mile therory... but nowhere is this written.
As long as you use a Racor made filter (Framm, Motorcraft or Racor)... all made by Racor and an oil that is either CI4+ or CJ4 spec'd (CJ4 is newest spec, but no synthetics as of yet - except Amsoil... but I do not recommend it due to no API certs)... you will be fine... and change your oil and filter every 5,000 miles even if using synthetic oil.
I would assume your good to change at 9,000 miles if your due for a change.
__________________
24" Wiper Blades
  #9 (permalink)
Old 08-02-2007, 05:06 PM
Bagmanners Bagmanners is offline
Bagmanners is starting off with a positive reputation.
I just read an interesting article regarding the new CJ-4 vs. CI-4+ Oil specifications. Now I'm not trying to start an oil debate, and the article comes from a site viewed by some as rivals, but I reckon since we all share an affection for our trucks, this might prove interesting reading. Check out: http://www.turbodieselregister.com/TDR57_Oil.pdf
  #10 (permalink)
Old 08-02-2007, 05:28 PM
Got Diesel?
Quote:
Great link....
Wow... I am glad that my choice of Rotella-Syn 5W-40 (CI4+) is rated as the #2 oil tested!!!!!
Wow, I used due to availability and cost... and darn glad I am!!!!
Surprised at some of the other "name brands" that did not test as well.... and always knew that the "racing" and MLM brands of oil were just hype and overpriced.
Great impartial oil analysis story... and yes, I do not do extended oil drains as I agree with their story... clean fresh oil and staying within the manufacture's service intervals is easier, less expensive and safer!!!
Great link... thanks.
__________________
24" Wiper Blades
  #11 (permalink)
Old 08-02-2007, 06:58 PM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is online now
Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.Frankenbiker has a great reputation on FTE.
frankenbiker
Having read this, I'm fairly curious now as to what they'd say to a Detroit Series 60 owner who essentially has access only to the "wouldn't cross the street for... " oils.... ??? I may have to start doing a little bit closer inspection on oils when I do my oil changes from now on....
On edit.... a little digging on the TDR website shows that CI4+ availability is remarkably limited... Might not have much of a choice any more. Thanks yet again to the EPA....
-blaine
  #12 (permalink)
Old 08-02-2007, 08:15 PM
duffman77's Avatar
duffman77 duffman77 is offline
duffman77 is gaining momentum as a positive member of FTE.
Where is the data in that link from the testing. thats just a bunch of virgin oil analysis' and a guy rating them by what he thinks what add pack will perform the best. The CJ4s may have a ho-hum add pack in his opinion, but thier is a reason they cost more, they use better base stocks and in general more expensive add packs.
  #13 (permalink)
Old 08-03-2007, 07:26 PM
frankenbiker
That's all they wanted him to do, was rate based on virgin analysis. Base stock will work for pure lubrication, but when you have to consider the other jobs the oil has to do, analysis of the additive package comes in to play. And I suspect the increased price of the CJ4's has to do more with the price of the base crude and market availability than the quality (or lack thereof) of the finished product.
-blaine
  #14 (permalink)
Old 08-03-2007, 07:38 PM
Keep in mind that CJ4 was intended to be used with the new ULSD fuel. Therefore, the additive package will be different as it was designed to be used with a fuel having a different chemical composition. The TBN is lower by design as the sulfur content in ULSD is significantly lower than LSD, thereby less need for neutralizing margin in the oil. That's why diesel engine manufacturers recommend cutting the oil change interval in half if you use CJ4 spec oil with LSD fuel.
__________________
Frank
  #15 (permalink)
Old 08-04-2007, 11:42 AM
PSD DickW's Avatar
PSD DickW PSD DickW is offline
2006 Ford F-350
PSD DickW has a very good reputation on FTE.PSD DickW has a very good reputation on FTE.PSD DickW has a very good reputation on FTE.
Hey, that's a great link! I've been thinking of switching over to Rotella-Syn 5W-40 before the winter,and now I'm sure. Once I've switched over I'll be staying with it. Thanks for the info.
__________________
Dick
Member of the Massachusetts Chapter
"We get too soon old and too late smart"
PJ - RIP
Tags
5w40, brad, cj4, diesel, dk, f250, filter, motor, motorcraft, oil, penn, pris, racor, rotella, shell, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
