Turbocharging the 302 - Ford Truck Enthusiasts Forums
Old 04-12-2000, 06:45 PM
cbwarrior's Avatar
cbwarrior cbwarrior is offline
cbwarrior is starting off with a positive reputation.
Does anyone know what it would take to turbo an 88 F150 with a 302 5spd? I've been told that the forced induction of a super/turbo charger would go beyond the limits of the speed density system, that I'd have to go to a mass airflow type system. Does anyone have any experience with this? If I do need to change over, what would be a good donor vehicle for the parts, cause I'm figuring that junkyard parts would be cheaper. Also what would be a good donor for a turbo for me to use with this system? I know I sound cheap, but wedding bells are in the future, along with college loans, etc., so money is tight. Any help on this would be greatly appreciated, and thanks in advance for the help!
Old 04-18-2000, 02:53 PM
jay_1 jay_1 is offline
jay_1 is starting off with a positive reputation.
Old 05-14-2000, 12:22 PM
69man 69man is offline
69man is starting off with a positive reputation.
ok from my reaserch into turbocharging this is what you need. you need special built manifolds, you need turbo(s), you need wastegate(s), and posibly a intercooler(it is not needed but is helpful for getting the full potential of the turbos. here are some sites 1. www.turbocity.com, 2. http://members.aol.com/stang8s/index.htm
hopefully these help, if you need a system turbosity will help you make one, the other site is a guy who races a twin turbo mustange. 3. http://www.classictruckshop.com/clubs/earlyburbs/projects/turbo/charging.htm, this one is a guy who has done superchagering on his trucks before.
good luck 69man
Old 05-14-2000, 12:24 PM
he has turbocharged his trucks before.
http://www.turbocity.com
good luck
69man
Old 05-14-2000, 08:04 PM
cbwarrior's Avatar
Thanks for the info!! I'll check that out!
1978 ford f100 302 efi conversion help derk001 Engine Swaps 8 10-04-2012 09:59 AM
1951 F1 motor, trans, & rear end help. jes26201 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 07-29-2012 02:16 AM
Banks Turbo removal/install Dave7.3 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 07-09-2006 01:44 AM
Turbo Kit kyhusker 6.0L Power Stroke Diesel 7 11-11-2005 03:20 AM
Single turbo 302? Polkat Performance & General Engine Building 11 08-05-2003 03:12 AM
Tags
302, 50, 88, chargeing, charging, density, f150, ford, motor, speed, truck, turbo, turbocharged, turbocharger, turbocharging
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
