Quote:
Originally Posted by psd76
I dont have any residual glue from the decal just an outline from the weathered and covered paint. I am going to clay bar, paint cleaner, polish then wax the whole truck. When using the clay bar do I go in straight lines? Thanks for all the suggestions.
It doesn't make any difference in what direction a clay bar is used.
A clay bar MUST be used with a lubricant. Mothers or Meguiars qwik detail works fine. If you buy a clay bar kit, it will come with the lubricant. Do NOT use a clay bar on hot metal, clay streaks will result. They aren't harmful, but can be a PITA to remove. Even if the metal is cool, you need to keep the area wet with lubricant. You don't need to rub hard = go easy, let the bar glide along the surface.
You will be amazed on how smooth the finish is after you use the bar. Car washes, most waxes and polishes, will not remove most of the pollution (fall out). Get another clay bar, use it on glass...use Windex or Invisible Glass for a lubricant.
