Lowering a 1970 F-100
Old 12-18-1999, 11:00 PM
Josef Girouard
Guest
Posts: n/a
Anyone know of a cheap/easy way to slam a '70 f-100 without having to purchase $600 i-beams?
I have a kit to lower the rear end 5" already,
SOMEONE PLEASE HELP ME.
Old 12-19-1999, 04:48 PM
Trail_Rider's Avatar
Trail_Rider
Trail_Rider is offline
Give me your address and I'll come haul it off for you so we can keep old Fords from getting screwed up like that. Then you can by a CHEV-RO-LET, and screw it up to your hearts content.
Old 12-19-1999, 04:53 PM
Trail_Rider
...actually, yes there is a way. It's major surgery so you'll be down awhile. What you need is the entire front end off a Volare/Aspen. The entire front frame section is a bolt on since it's a unibody. It comes off with 3 or 4 bolts then you lift the body off of it. It's called the K member. Once it's off of the car you've got disk brakes and an adjustable torsion bar front suspension. The entire front end is complete. Then all you have to do is graft it to the front of the truck.
Trail Rider
Old 12-19-1999, 09:58 PM
Ben_E's Avatar
Ben_E
Ben_E is offline
"Anyone know of a cheap/easy way"
Take out the front coil springs and cut a coil or two off with a angle grinder or somthing and hope it sits leval. I have seen this done, and although it looks cool the ride quality suffers greatly.
Old 07-04-2000, 01:09 AM
FE427TP's Avatar
FE427TP
FE427TP is offline
I dont know where you are finding $600 I beams, AIM has the for about 350-400 I believe, it's the better way to lower it, as for trail rider, everyone has their own opinion, he obviously must not want a trail truck, if it's a street only vehicle lowering it becomes a valid option. is raising a truck or potentially damaging it on trails screwing a truck up too? there are always two sides to a discussion like this. and Josef, take your time, save the money and make sure it's done right, trail rider is right that a poorly or cheaply done job WILL screw your truck up, do it right the first time and you'll be happier
Old 07-05-2000, 03:42 PM
broncotwo's Avatar
broncotwo
broncotwo is offline
jamhh
07-25-2016 09:26 PM
wesley49
01-26-2016 03:30 PM
dmilob12
12-18-2015 07:25 PM
cbfatm
12-17-2009 12:40 AM
psyko64
08-05-2004 11:08 PM
Quick Reply: Lowering a 1970 F-100
