Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 07-30-2007, 05:26 PM
Baumbach Baumbach is offline
Garage is empty, add now
Baumbach is starting off with a positive reputation.
How to turn off Key in ignition chime
I like to park, open the doors and turn the radio on, (tailgate party) with the key in the accessory position all you hear is the warning chine going off non-stop reminding you that the key is still in the ignition.
I took the dash apart to get at the chime hoping it could be un-plugged, but found the same chime is used to warn / alert you have other things, so here is what you can do.
Open the driver’s door; on the door take a screwdriver, ball point pen, pencil, stick, or similar item and push the clamps in so it thinks the door is locked closed, No more chime!
Just remember to pull on the door handle to open them again before you try to close the door. You will need to lightly close the door and pull the handle again to get them to open all the way.
  #2 (permalink)
Old 08-30-2007, 03:01 AM
Monsta's Avatar
Monsta Monsta is offline
2005 Ford Excursion
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Excellent Post! :d
__________________
Ken
"Socialism, like the ancient ideas from which it springs, confuses the distinction between government and society. As a result of this, every time we object to a thing being done by government, the socialist concludes that we object to its being done at all. " -The Law, Frédéric Bastiat, 1850
Tags
2010, 97, alarm, chime, disable, door, escape, f150, ford, fordkeyin, ignition, key, located, ranger, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
