Where does this vacuum hose goes to ? anyone know?
Old 07-30-2007, 01:13 PM
DJdemon6696's Avatar
DJdemon6696
DJdemon6696 is offline
its from my other post about missfiring .. but it will get more atencion this way .. for it... so here is the pic
the orange Hose where does it goes.. what does it do ? where does it come from ?
here is the other post
https://www.ford-trucks.com/forums/6...isfirin-3.html
Old 07-30-2007, 02:08 PM
rattosh51's Avatar
rattosh51
rattosh51 is offline
Don't know what it's for or is, but there's got to be another end somewhere??
Old 07-30-2007, 02:24 PM
DJdemon6696
yeah its coming from all of the other hoses.. on the other side of the intake..
Old 07-30-2007, 02:41 PM
92F150Flare's Avatar
92F150Flare
92F150Flare is offline
Cap it off till you find out.....might not even need it....but sure don't need it open!!
Bob
Old 07-30-2007, 03:25 PM
alxsnmr's Avatar
alxsnmr
alxsnmr is offline
I cant see a picture of it at all. If it is coming off the intake then it is going either to the brake booster, vacuum resivior, vacuum resevior/cruise, HVAC, Fuel pressure regulator, or the c6 if so equipped. Then the passenger vacuum reserve supplies the thermactor switches and the egr switch. Depending on the switch they would control the thermactor bypass or the cat/head flow of the A.I.R. system, this has to be determined by the signal wire color to figure out which vacuum switch is being operated. I could not see your picture of the hose. Also the truck has listed in the engine bay the proper vacuum hose routing by color of the hose if it has not been destroyed by the years.
Old 07-30-2007, 06:02 PM
bobcf's Avatar
bobcf
bobcf is offline
Old 07-31-2007, 01:54 PM
DJdemon6696
From the pic that " BOBCF " posted.. i can see a vacuum lines that is going to a thing called "AIR D" .. where is that? what is it ?
Old 07-31-2007, 03:03 PM
tomtoc's Avatar
tomtoc
tomtoc is offline
googling turned up this link:
http://townhall-talk.edmunds.com/dir.../.ee94b92/1316
look at post 1322.
not sure if that helps
Old 08-01-2007, 12:13 PM
DJdemon6696
Pluged up the Hose.. and now it idles Smooth smooth
Old 08-01-2007, 01:40 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
Air D is the Thermactor air diverter (TAD) valve that controls whether the smog pump sends air to the back of the cylinder heads or if it sends it down to the exhaust between the cat. converters...
The Outlaw
02-20-2017 11:58 AM
The Outlaw
07-30-2016 04:29 PM
edzakory
10-25-2015 07:31 AM
Freaksh0w
Oil & Lubrication
25
11-16-2010 07:27 AM
savage2211
Ride Of The Week
03-08-2009 06:52 PM
Quick Reply: Where does this vacuum hose goes to ? anyone know?
