Where does this vacuum hose goes to ? anyone know? - Ford Truck Enthusiasts Forums
Old 07-30-2007, 01:13 PM
DJdemon6696 DJdemon6696 is offline
DJdemon6696 is starting off with a positive reputation.
its from my other post about missfiring .. but it will get more atencion this way .. for it... so here is the pic
the orange Hose where does it goes.. what does it do ? where does it come from ?
here is the other post
http://www.ford-trucks.com/forums/63...isfirin-3.html
Old 07-30-2007, 02:08 PM
rattosh51's Avatar
rattosh51 rattosh51 is offline
rattosh51 is starting off with a positive reputation.
Don't know what it's for or is, but there's got to be another end somewhere??
Old 07-30-2007, 02:24 PM
yeah its coming from all of the other hoses.. on the other side of the intake..
Old 07-30-2007, 02:41 PM
92F150Flare 92F150Flare is offline
92F150Flare is gaining momentum as a positive member of FTE.
Cap it off till you find out.....might not even need it....but sure don't need it open!!
Bob
Old 07-30-2007, 03:25 PM
alxsnmr alxsnmr is offline
alxsnmr is gaining momentum as a positive member of FTE.
I cant see a picture of it at all. If it is coming off the intake then it is going either to the brake booster, vacuum resivior, vacuum resevior/cruise, HVAC, Fuel pressure regulator, or the c6 if so equipped. Then the passenger vacuum reserve supplies the thermactor switches and the egr switch. Depending on the switch they would control the thermactor bypass or the cat/head flow of the A.I.R. system, this has to be determined by the signal wire color to figure out which vacuum switch is being operated. I could not see your picture of the hose. Also the truck has listed in the engine bay the proper vacuum hose routing by color of the hose if it has not been destroyed by the years.
Old 07-30-2007, 06:02 PM
bobcf's Avatar
bobcf bobcf is offline
bobcf is starting off with a positive reputation.
Old 07-31-2007, 01:54 PM
From the pic that " BOBCF " posted.. i can see a vacuum lines that is going to a thing called "AIR D" .. where is that? what is it ?
Old 07-31-2007, 03:03 PM
tomtoc tomtoc is offline
tomtoc is gaining momentum as a positive member of FTE.
googling turned up this link:
http://townhall-talk.edmunds.com/dir.../.ee94b92/1316
look at post 1322.
not sure if that helps
Old 08-01-2007, 12:13 PM
Pluged up the Hose.. and now it idles Smooth smooth
Old 08-01-2007, 01:40 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Air D is the Thermactor air diverter (TAD) valve that controls whether the smog pump sends air to the back of the cylinder heads or if it sends it down to the exhaust between the cat. converters...
Mid Fifties Shindig edzakory 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-25-2015 07:31 AM
Interesting mirror 78 & 87 Super Cab 1973 - 1979 F-100 & Larger F-Series Trucks 8 09-29-2013 02:00 PM
First Pics - 2011 F250 Lariat Shakedown St. 6.7L Power Stroke Diesel 30 08-27-2010 07:30 PM
1990 F150 suspension (lowering) help!! DJdemon6696 1987 - 1996 F150 & Larger F-Series Trucks 13 01-28-2010 09:36 PM
INLINE SIX to an smallblock V8 engine swap write up DJdemon6696 1987 - 1996 F150 & Larger F-Series Trucks 0 06-29-2009 09:50 PM
Tags
89, 91, bronco, f150, ford, fuel, hose, intake, line, orange, pressure, regulator, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
